Previous in Forum: Impact Drive   Next in Forum: Lifting Structure Help
India - Member - New Member
Pipe Class
11/28/2010 6:37 AM
can any one expalin what is pipe class in MS piping,Like Class-A,Class-B,Class-C etc
is it same as schedule?? whether i need to spacify Pipe schedule with Class
thanks in advance
Re: Pipe class
11/28/2010 9:28 AM
Industrial Pipe SpecificationsGlobalSpec offers specifications, definitions, help page and tutorial about Industrial Pipe for engineers and through SpecSearch the Industrial Pipe can be ...
www.globalspec.com/Specifications/.../Pipe.../Industrial_Pipe - Cached
ISO - Pipe, Tube and Fittings Standards and Specifications
ASME Specifications
And, my personal favorite. This is a MUST READ
Pipe Specifications
►Pipe Specifications
1. All pipe is to be made of a long hole, surrounded by metal, plastic concrete, clay or ceramic material around the hole
2. All pipe is to be hollow throughout the entire length –do not use holes of different length than the pipe.
3. The inside diameter of all pipes must not exceed their outer diameter –otherwise the hole will be on the outside.
There's more, check it out.
Re: Pipe Class
11/29/2010 9:11 AM
somewhere i found as well as pipe class changes thickness also changes so it is doubtfull for me as i understand it represent tensile strength
Register to Reply 2 comments
