Previous in Forum: Multiple Physics Exploitation   Next in Forum: Tube Material for Cooling Water Service
Three Phase Motor
12/02/2010 11:39 AM
wat tests to do on a three phase motor.should readings be the same between windings,wat readings will i get if motor is faulty
Pathfinder Tags: testing three phase motor
Re: three phase motor
12/02/2010 12:01 PM
Ask the manufacturer, perhaps?
Re: Three Phase Motor
12/02/2010 2:07 PM
This is a fairly commonly-asked question on CR4. Try a search of CR4 for more information as I believe this question has been answered before.
12/02/2010 2:13 PM
1.wat tests do i do on a three phase motor:
depending on wat you'd want to check on your motor but here are a few tests you can do on your motor: *insulation-resistance test * resistance test *earth fault *amperage test *speed test... etc
2.should readings be the same between windings;
They should definately be the same. in some instances you may get a difference of say: u=3.7ohms v=3.8ohms w=3.8ohms. i'd say this is acceptable as some variances may emanate from your multimeter or the point of contact when you carryout the test.
3. a faulty motor gives weird readings, maybe an open circuit, open winding readings
Register to Reply 3 comments
ezingore (1); jack of all trades (1); PWSlack (1)
