Previous in Forum: TV Spark Gaps   Next in Forum: Sheath Voltages
electrics for a pmbldc motor
12/02/2010 3:19 PM
using a pmbldc motor turning it backward, like a generater, is there anyone in the arizona area that can fabricate the electronics for this "motor" to putout 2 amps, at 800 rpm and protect the system as in overvoltage, temp.control, reverse poliarity all that is needed for 110 60 cycle ul listing? thanks I will make you rich.
old age and treachery will overcome youth and vitality
Good Answers: 29
Re: electrics for a pmbldc motor
12/02/2010 4:15 PM
12/02/2010 4:28 PM
Permanent magnet brushless direct current motor.
The 800 rpm doesn't coordinate too well with 60 Hz, but I don't know what tolerance may apply.
12/02/2010 7:26 PM
sorry, i am an airplane sheet metal mechanic. i know very little about electrics. I have a patent pending and need to perfect the energy system for it. do you live in Ariz? the rpm is not important at this stage but must be able to start producing elect power at about 200 rpm.
12/02/2010 7:29 PM
you must be very young.
12/02/2010 8:14 PM
Why not just plug it in?
So far this project is too vague to advise well. There may be proprietary reasons for that, but it would help to know the general nature of the electrical loads this generator needs to supply.
12/02/2010 8:56 PM
sorry, this blog site is too open to really describe what i am upgrading. my patent is still pending.if you give me a phone # I will call and describe what I need. eddie
12/04/2010 12:24 AM
If it can't just be plugged in, one guess is that this would be a mobile device. If it is engine-powered, is there a starting system that includes an alternator and a battery? If so, a cigarette-lighter style of inverter could give you the power you need.
Register to Reply 7 comments
incognitoeddie (3); RDGRNR (1); Tornado (3)
