Previous in Forum: Tube Material for Cooling Water Service   Next in Forum: Custom Built Rotary Vane Crank Pump
Counterbore
12/03/2010 12:18 AM
Simple question: What is the purpose of counterbore in blind flanges for NPT fittings in class 300 and above?
Re: Counterbore
12/03/2010 12:34 AM
To make sure that the wrench flats of various nuts and bolts are sunk far enough below the adjacent surface that you can't get a good grip. Any experienced mechanic has seen this so many times that there is no longer any mystery about it.
You might be interested in: Pipe Flanges, Hose Fittings, Tube Fittings
