Previous in Forum: Statutory Bodies in Singapore   Next in Forum: 33kv Cable
Motor Terminal Box Clearances
12/03/2010 2:30 AM
Kindly anyone can say what is the standard and number to be followed for minimum phase to phase and phase to earth clearances for different voltage levels of motor terminal box.
Re: motor terminal box clearances
12/03/2010 4:05 AM
The manufacturers of the motors would be a good direction in which to make the telephone call, perhaps?
12/03/2010 10:15 AM
But the motor manufacturer has a reputation to preserve. They're likely to give our guest an answer he doesn't like.
Re: Motor Terminal Box Clearances
12/03/2010 10:26 AM
An impractical rule of thumb is to provide a quarter furlong of clearance for every twelve thousand four hundred thirty two poncelets of power.
Another method is to first find out what the local wiring standard for the location of your installation. Then read the standard and follow it.
The easy method is to hire a licensed local electrician at the installation site.
12/03/2010 10:34 AM
Kindly say where the jobsite is located.
Good Answers: 244
12/03/2010 4:03 PM
See NEMA MG 1, Section 4.19.
Also see this thread: http://cr4.globalspec.com/thread/56978/Clearance-in-Terminal-Box-of-Motor
- MS
Good Answers: 42
12/04/2010 10:50 AM
For large AC and DC machines many electricians find the standard terminal boxes are too small. It is often an OEM option to have an oversized conduit box supplied instead. I have seen many end users replace the OEM boxes with their own custom made oversized boxes.
GW (1); lyn (1); msamad (1); PWSlack (1); redfred (2)
