Ok, I recently took apart my Laptop (Packard Bell Easynote R4622), due to DC plug connection issues. After re-soldering the new DC plug onto the motherboard, I put it back together, it worked perfectly. Today, whilst I was using it, first the screen just turned off. Restarting it, booting it back up, it blue screened. This happened several times (Safe mode also blue screened). Following that, I started it, and it worked perfectly again for another 50 minutes or so, until once again it blue screened, losing my work. When I turn it on if it doesn't blue screen, it will freeze and be completely unresponsive. I then reformatted my hard drive, installed Windows 7 (again!) and turned it on, to which it blue screened. I have tried the old hard drive too, running Windows XP, and it also froze, which makes me think it is hardware related. Does anyone have any ideas as to what may be causing the problem, I'm thinking maybe the processor has bit the dust... Any advice would be welcome. It now won't start. Thanks
Bondy.
