Previous in Forum: Sprinkler System Pressure Requirements   Next in Forum: Fluid Coupling Replacement
Mating Orifice Flange With a Standard Flange
12/04/2010 3:31 PM
Is it possible to mate an orifice flange with a standard flange?
Thanks for your input.
Re: Mating orifice flange with a standard flange
12/04/2010 4:28 PM
Yes.
Good Answers: 61
Re: Mating Orifice Flange With a Standard Flange
12/05/2010 3:18 PM
Guest,
I would like to know why you are going to do this?
Is it because you need a flanged joint and you have one weld-neck and one set of orifice flanges?
What?
Do it once and do it right
12/08/2010 4:43 AM
Hello PennPiper,
I require a pressure tap at the location of the flanged joint. I won't be using an orifice and therefore, I do not require both flanges to be orifice/pressure tapped flanges. Since orifice flanges come with standard pressure taps, I was wondering if I could use one orifice flange and one standard flange to make the joint and use the pressure tap on the orifice flange for my application.
Thanks,
OP
Anonymous Poster (1); PennPiper (1); Tornado (1)
