Previous in Forum: Generator without fuel engine   Next in Forum: Power generation
43 comments
What meaning did these abbrevations stand for?
03/23/2007 4:00 AM
No matter where you are, you will often see many abbrevation in books, magzine and documents and labels etc. Some of them are unique but most of others are very confusion so as to misunderstand and maybe lead to joke.
My electric knowledge is very elementary and I met once not long before on the forum. Someone may be remember at once as soon as I metion now. "CT" in a post. he want to make one and hnow its principle. Have a guess pls,everybody, do you know what I think of the ct? I thought of " computer tomography" at once. as I hve ever repaired and dealed with some simple real time imaging machine, I think its large and complex enough at present, and cannt be explained by several words.it will concerned with much knowledge like HV and HF power,motor control, transportantion system and computer graphics processing etc. from the thread he seems just to know the current relation. it seems only a current sensor or somethnk like it else. I asked what it the "ct"? returned impatient "current transducer". oh, I see, thats easy. I can help at the very spot. transformer type or hall type? We used, wired and selled, of cause I can right offer some information more or less.
This is a simple example, from this, you can read several abbrevation like "CT", "HV", "HF" etc. now most of us out there will know its concept, but maybe someone still read these as another concept, for example, HF can be considered as "High fortune right" or others else.
So I think if we could list here as more possible as we could come across the abbrevation somewhere or in our work daily? We are from all of the world, there will maybe interesting.
Pathfinder Tags: abberavtion data terms test unit
Re: What meaning did these abbrevations stand for?
03/23/2007 4:23 AM
Let's start, I shall put down some at first and holpe they are useful.
NDT, nondestructive test. a test method of no destroy material and can get its inner structure information. similarly.
NDE, NDI, means nondestructive evaluation, nondestructive inspection.
RT, radiographic test, use x-ray, or r-ray radiation penetrate material to get image on film or CRT, LCD monitor through sensor. it use widly in pipe, vessel, machenism etc manufactuers.
CRT, cathod radiation tube. LCD, liquid crystal display.
UT, ultrosanic test, use ultrosanic wave's reflection to position material or parts fault. it divided into several method: A scan, B scan, C scan and P scan etc. now we can config with computer to get stereo graphic.
MT, magnetic field test. use magnetic particle under strong magnetic field to show and locate fissure of parts surface.
ET, eddy test. use eddy produced by high frequency current to detect fault of pipe, tube or plate etc. mainly use for thin wall.for example less than 7mm etc.
PT, penetrate test, use liquid soluted some colored tiny particle spray on surface of parts.
IR, infrared ray radiation or infrared image equipment test. according to temperature defferent to image on lcd or crt like a vedio camera.
RTIS, real time image system,
VFD, variable frequency device or inverter. (not volunteer reserve decoration.)
CT, compute tomographic or current transducer
GF, graphics format. there are lots of formats such as gif, bmp, jpeg, tif, p...
PM, project management
ERP, enterprise resource plan or enterprise resource project management
IPMA, international project management association
ISO, international standards orgnazition
IEC, international electric committee
ASME, american society of machinery engineers
IEEE,international electric and electronic engineer society
UL, underwriters' laboratiries
DIN, germany industrial standards, germany film sense speed unit.
JIS, japanese industrial standards
BSI, british standards institution
SMPTE, american society of motion picture and tv enginerrs; a kind of time code recorded on medium.
NZR, nonzero recording.
Kv, kilo votage
mV millivotage
mW, milliwatt
MW, megawatt
mA, milliampere
GP, gererator plant
3P, 3 phases
HP, horse power
MPU, micro processor unit, uP
GPS,
HD,
CD,
DVD,
OS,
EG, haha electronic games. last century I played it day and night, from ground to bed... I remember the cpu is 6502 as same as in Apple II and programme is fixed in fireware and display on tv set.
continue...
Good Answers: 804
03/23/2007 8:21 PM
Typical, as relating to Electrical issues anyway;
RT = Real Time
CRT - close. Cathode RAY tube.
UT - don't know for sure, but in relation to molded case circuit breakers it would mean Undervoltage Trip
MT = sometimes used as an abbreviation for Motor
ET - don't know
PT = Potential Transformer, i.e. voltage transformer used for metering
IR = Infra Red, (no "ray", but "radiation" is implied without necessarily stating it)
RTIS = Real Time Information System
VFD = Variable Frequency Drive; also means Vacuum Fluorescent Display
CT = Current Transformer
GF = Ground Fault (you may know it as earth fault, earth leakage)
PM = Permanent Magnet, can also mean Preventative Maintenance depending on context
ASME = American Society of Manufacturing Engineers
GP = General Purpose, as in not necessarily heavy duty, not robust
3P = 3 pole. 3 Phase is usually abbreviated 3Ph
GPS = Global Positioning System, sometimes used for Ground Protection System
HD = Heavy Duty (robust); sometimes misused to mean HID for High Intensity Discharge relating to lighting.
CD = Compact Disc, also means Cross Dresser here in San Francisco
DVD = Digital Versatile Disc (most people think it means Digital Video Disc but that is incorrect)
OS = operating Systems (i.e. MS DOS, OS2, Unix, Linux etc.)
EG = Electro - Galvanized, as compared to HDG, Hot Dip Galvanized. Depending on context, it can also mean "example given", but is usually abbreviated e.g. in that case, e.g.
03/24/2007 12:47 AM
RTOS - Real Time Operating System
HDD - Hard Disk Drive
FDD - Floppy Disk Drive
I2C - Inter IC Communication
TCP - Transmission Controll Protocol
IP - Internet Protocol
HVDC - High Voltage DC
HVAC - High Voltage AT
GPRS - Global Pocket Radio System
GSM - Global Service Mobile
CAN - Controller Area Network
USART - Universal Synchronous Asynchronous Receiver Transmitter
SPI - Serial Peripheral Interface
ASICII - American Standard Institution Code for Information Interchange
thats all for now and i will add more soon..............
Mohamed Thalib
03/24/2007 1:17 PM
HVAC also stands for Heating Ventilation and Air Conditioning.
rega451
03/27/2007 5:30 PM
hvac here should be more specific High Voltage Alternating Current
and hvdc...High Voltage Direct Current
03/29/2007 4:20 AM
tHANKS EngX for correcting it .. i didnt have enough time to correct it thats why sorted AC and DC
Mohamed Thalib
03/29/2007 4:06 AM
OEM - Original Equipments Manufacture
EDS – Electronics Design Service
EMS – Electronics Manufacturing Service
POSIX – Portable Operating System Interface uniX
ASCII – American Standard Code for Information Interchange
ASIC –
PIN – Postal Index Number
PIN – Personal Identification Number
RBC – Red Blood Cell
WBC – White Blood Cell
CT – Computer Tomography
ECG – Electro Cardio Grapy
EEG – Electro Encephalo Grapy
EMG – Electro Myo Grapy
ERG - Electro Retino Grapy
EOG - Electro Oculo Grapy
UV – Ultra Voilet
US – Ultra Sonic
Mohamed Thalib
03/26/2007 11:55 PM
thax, you correct some mistake of mine. very good.
03/24/2007 12:22 PM
CT center tap (of tranformer)
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
03/26/2007 5:19 AM
What about "TLA"?
03/26/2007 10:56 AM
From Railway engineering:
FPL - facing point lock
AVB - automatic vacuum brake
In line with certain aspects of humour in this part of the world, many former railway companies acquired nicknames to go with their company initials as presented on the rolling stock and locomotive fleet:
GWR - Great Western Railway or Great Way Round, or Gresley Was Right
LMS - London, Midland & Scottish, or Late, Mouldy & Slow.
LNER - London & North Eastern Railway, or Late & Never Early Railway
M&GN - the Midland & great Northern (Joint Railway), or Muddle & Go Nowhere.
SDJR - Somerset & Dorset Joint Railway, or Slow, Dirty & Jolting Railway
OWW - Oxford, Worcester & Wolverhampton (Railway), or Old Worse & Worse.
Particularly unfortunate in this respect were the Swansea Harbour Trust, and the Weston, Clevedon & Portishead, whose initials in themselves were sufficient to defy all further attempts at desecration...
Good Answers: 75
03/27/2007 9:26 AM
Don't forger
NTSC meaning Never The Same Colour
Good Answers: 75
03/24/2007 8:59 AM
I have just one thing to say CRIMINAL
Good Answers: 18
03/26/2007 9:05 AM
How about NFW?
04/04/2007 7:50 PM
Now found wanting.
Good Answers: 27
03/24/2007 9:32 AM
Abbreviations for technical and non-technical terms are used in various fields worldwide and the result is they may differ in both spelling and meaning. There are published national standards and dictionaries of technical terms but, in my view, it is pointless to attempt to define universal abbreviations.
A far better (and universally accepted practice) is to avoid using an abbreviation until the word has been spelled out completely and the associated abbreviation defined. For example, A current transformer (CT)........................Thereafter CT can be used in the article, paper or post without confusion.
Good Answers: 75
03/24/2007 11:44 AM
Bluestone is correct and it is very helpful to supply the complete filled out version in the first instance. Another technique is the one I used in my earlier post where the acronym CRIMINAL is actually a link and if you click on the link it will take you to a full definition.
Popular Science - Weaponology - Cardio-7
03/26/2007 10:41 AM
Finally, someone said it.
Most abbreviations are field-of-use informative. For most computer or electronics abbreviations, the same abbreviations mean something entirely different to a chemist or a medical doctor. HF, for example would mean hydrofluoric acid to a chemist or chem engineer. The accepted standard, when one is not writing for a specific application (i.e., a textbook on a specific subject), is to define each abbreviation the first time it is used, or to refer to an appendix for definitions of abbreviations used.
04/04/2007 7:52 PM
Surely not it is hydrogen fluride.
Good Answers: 804
03/26/2007 9:40 PM
While all that is true, I might point out that this is posted in the ELECTRICAL ENGINEERING forum!
Context is everything.
03/27/2007 3:40 AM
I agree to bluestone, although this is electric forum, but the visitors are from very different field, so they will have differnt idea for the same abbrevation.
another example: PID. we know very well a way of control in engineering. but we can also thnk it as piping instruments diagram. they are very differnet.
Good Answers: 804
04/15/2007 5:05 PM
That is actually abbreviated P&ID, specifically to differentiate it from PID because both terms are used in the same industry.
Good Answers: 75
03/27/2007 9:34 AM
Just out of curiosity, did anybody bother to actually follow the link that is associated with my CRIMINAL acronym
03/27/2007 9:46 AM
Yes.
Acronyms are on the Red List, though it's OK as they were not discharged to a watercourse.
Good Answers: 27
03/27/2007 1:04 PM
I did and just happen to agree.
Good Answers: 75
03/27/2007 2:39 PM
Thanks for the response Bluestone, at least I know going to the trouble of putting the hyperlinks in is not a total waste to time.
03/27/2007 9:46 PM
Hi, Masu, I visit your that thread posted on 1.18. its wonderful acronym. I know there are lots of such acronym which of some are very different from its original meanning.
mine thread is same as yours I think, butr we couldnt visit by the time the taiwan earthquake and the optical fibre was broken. we hard to access to the room.
-----Just out of curiosity, did anybody bother to actually follow the link that is associated with my CRIMINAL acronym---------
nasa and ...
03/28/2007 3:22 AM
PCMCIA :- People Can't Memorise Computer Industry Acronyms
03/28/2007 3:25 AM
WOM - Write-only memory - the bin?
Good Answers: 75
03/28/2007 5:32 AM
CFC- Circular Filing Cabinet, also the rubbish bin
03/28/2007 5:35 AM
Interesting. In other fields CFC stands for chlorofluorocarbons.
03/28/2007 9:41 PM
there will be lots of interesting abbrevation especially in advertisement. some of them is interesting in some area, but in other area will be considered very opposite. of cause their produce advertised will be reduced selling in that area.
03/29/2007 4:08 AM
EMF – Electro Motive Force
MMF – Magneto Motive Force
RMF – Rotating Magnetic Field
RMS – Root Mean Square
CT – Current Transformer (or) Current Transducer
PT – Potential Transformer (or) Potential Transducer
VT – Variable Transformer
VARIAC – VARIable AC (Auto Transformer)
Hz – Hertz
HF – High Frequency
LF – Low Frequency
MF – Medium Frequency
VHF – Very High Frequency
UHF – Ultra High Frequency
IC - Integrated Circuit
LIC – Linear Integrated Circuit
SSI – Small Scale Integration
MSI – Medium Scale Integration
LSI – Large Scale Integration
VLSI – Very Large Scale Integration
SOC – System On Chip
SIP – System In Package
FPGA – Field Programmable Gate Array
ASIC – Application Specific Integrated Circuit
Mohamed Thalib
03/29/2007 4:12 AM
LED – Light Emitting Diode
LCD – Liquid Crystal Display
TFT – Thin Film Transistor
CMOS – Complementary Metal Oxide Semiconductor
FET – Field Effect Transistor
JFET – Junction Field Effect Transistor
MOSFET - Metal Oxide Semiconductor Field Effect Transistor
MONOS – Metal Oxide Nitride Oxide Silicon
SCR – Silicon Controlled Rectifier
LASCR – Light Activated Silicon Controlled Rectifier
OPAMP – OPerational AMPlifier
LVDT – Linear Variable Differential Transformer or (Transducer)
RVDT – Rotational Variable Differential Transformer or (Transducer)
TTL – Transistor Transistor Logic
DTL – Diode Transistor Logic
CMMR – Common Mode Rejection Ratio
ADC – Analog to Digital Converter
DAC – Digital to Analog Converter
RADAR –
SONAR –
RoHS – Restriction of Hazardous Substance
LASER – Light Amplification Stimulated Emission of Radiation
RFID – Radio Frequency Identification Tag
GPRS – General Packet Radio Service
GPS – Global Positioning System
DFT – Discreet Fourier Transform
FFT – Fast Fourier Transform
TDMA – Time Division Multiple Access
CDMA – Code Division Multiple Access
FDMA – Frequency Division Multiple Access
PSD – Phase Sensitive Detector
PWM – Pulse Width Modulation
LAN – Local Area Network
WAN – Wide Area Network
MAN – Metro Area Network
POP – Post Office Protocol
SMPT – Simple Mail Transfer Protocol
WWW – World Wide Web
WAP – Wireless Application Protocol
SMS – Short Message Service
MMS – Multimedia Message Service
MCU – Micro Controller Unit
MPU Micro Processor Unit
CAN – Controller Area Network
LIN – Local Interconnect Network
Mohamed Thalib
Good Answers: 75
03/29/2007 5:58 AM
Thank you mohammadthalif for that comprehensive list of acronyms.
Ultimately however, if you don't want your post to be FUBAR and avoid a SNAFU then in the first instance use the full version then follow it with the acronym.
This is an international multi discipline forum and acronyms vary in interpretation across both. It's just polite to let your readers know what you mean by using the full version in the first instance.
03/29/2007 10:52 PM
RADAR (radar) - Radio Detection and Ranging
SONAR (sonar) - Sound Navigation and Ranging
rega451
04/02/2007 3:38 AM
So, what about TLA?
Good Answers: 75
04/02/2007 8:13 AM
04/02/2007 8:32 AM
Wikipaedia scores again.
Re: What meaning did these abbreviations stand for?
04/04/2007 3:51 AM
hi masu, the link you posted was excellent. i think its contains all acronyms mixed up together. we have to extract the electrical oriented acronyms separately..
any way thanks a lot for giving this link.. its look like a important dictionary for engineers.
Mohamed Thalib
04/15/2007 5:19 AM
TLA == Three Letter Acronym :)
06/18/2007 9:33 PM
TLA transient line surge arrestor
Good Answers: 88
01/20/2008 7:23 PM
Let us not forget the acronym ACRONYM: Alphabetic Co-location for Reducing Or Numbing Your Memory.
Register to Reply 43 comments
Anonymous Poster (1); Bill (1); Bluestone (2); BrainWave (3); Cardio07 (1); cnpower (5); EngX (2); JRaef (3); masu (8); mohammadthalif (6); PWSlack (7); Randall (1); Rega451 (2); user-deleted-13 (1)
