Previous in Forum: Best UPS Systems   Next in Forum: Operation of Transformer Other Than Designed Frequency?
240v / 110v converter for 90-110v bodine motors
12/06/2010 1:30 PM
uk 240 / usa 110 converter advice needed
application is for control of bodine motors 90v - 110v dc amperage of the motors between 0.89a - 1.3a
i can go 1 or 2 ways with this either by a 240v/110v converter rated at 200 watts if my calculation is correct or head towards a rated transformer 240v/110v 2a
volts x amps = watts
further to this converter/converted power supply would be
cr4 forum reference
using kbelectronics speed controller rated 4amps or
a 110v bridge rectifier with capacitor before the input of the motor with speed control as i have both options that can be used
i understand that the amperage can spike so im also considering placeing a resister to protect the motor from the amperage spikes at start up/low speeds
would this be enough to power the motor or am i under powered considerably
this is for a few projects i am building at the moment
thankyou for any help offered
Re: 240v / 110v converter for 90-110v bodine motors
12/06/2010 8:55 PM
The simplest way to control the speed of your bodine motor is to use small variac(220V-3A) followed by full bridge rectifier.
I believe you are using the bodine motor to perform coil winding !
Reply to Forum Thread
