Previous in Forum: EMD Engine Standby Quick Starting for Power Generation   Next in Forum: Tube to Tubesheet Expansion Joint Calculation
Sheet Metal Design
12/08/2010 11:29 AM
Hi All, I was asked to design a sheet metal component.I am a new employee..so i have no much experience in this field.i want to give embosse in a 2mm thick sheet.can i know what is the maximum depth i can give it and can any one send me the design document on sheet metal? Thanks for the Help
Good Answers: 179
Re: Sheet Metal Design
12/08/2010 1:56 PM
Sorry to say this, but you need to find another job if you have no experience whatsoever designing sheet metal components....don't waste the company's funds & time trying to do so. You have really no business being in that position. Also, some poor smhuck trying to fabricate a sheet metal part that you may design (ill-designed) may fail and result in injuring, maiming or even killing that person. You will be legally held responsible for any ill-consequences that result from your actions.
Good luck in the new job hunt!
Good Answers: 183
12/08/2010 2:18 PM
Every body started some time from zero some had more chance than other. I know that in some countries if you are a technician you are asked to do any kind of job even totally out of your basic profession. I can understand that for making a living you could have to accept such situations.
What do you know ? What have you done before ? If we know that we can be more helpful.
You can go several ways but I think you should start by using one or more research engines and ask for the subject you are now interested in "sheet metal design". There are some basic rules you can learn quite rapidly but you MUST be very careful.
To give you a qualitative answer, it depends on the properties of the metal sheet you want to deform. Very important is the maximal specific deformation and the ratio between Rm and Re. The higher the more chances you have to deform without generating cracks.
Good Answers: 179
12/09/2010 10:27 AM
Just in case the OP decides to stay in that position I pray that the company he works for assigns a well experienced "Mentor" to help tutor the poor guy for a period of time to help him do things correctly and safely!
12/10/2010 1:00 AM
CR4 Moderator: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
Anonymous Poster (1); CaptMoosie (2); nick name (1)
