Previous in Forum: How Do the Voltage Between Neutral and Ground Decrease When the Value is 1.5v?   Next in Forum: Testing of 3MVA Cast Resin Transformer for Temperature Rise
9 comments
Increasing DC Motor RPM
12/08/2010 12:54 PM
Dear Engineers,
I newly joined to an organisation. We are using 75 KW DC motor to turn our kiln. The motor is designed to turn our kiln upto 1.35 rpm. However, we found the rpm of kiln is varying from 0.7 to 0.9 in a revolution. we are unable to increase the rpm though it was utmost priority of process department to increase the rpm to 1.2.
Can any body suggest us how we can increase the motor / kiln rpm. (Kiln alignment was checked and found to be in fairly well)
Sameer
Re: Increasing DC motor RPM
12/08/2010 12:57 PM
Reduce the amount of material in the kiln.
12/08/2010 12:58 PM
Put some grease or lubricants....My kiln is pefect after that, faced a same problem.
12/08/2010 1:02 PM
I would check the motor voltages and line currents right at the motor to see if they are correct. A low armature voltage will cause the motor to run slow and a high field voltage can do the same.
Next I would inspect the motor itself to see if any brushes are burned out or stuck. After that I would check the speed controlling system over to see if its damages, worn out or simply miss adjusted.
12/09/2010 3:49 AM
Thanks for the nice reply. We are checking on the points. However, request you to please sent what checks we can make in the drive panel.
12/08/2010 1:10 PM
If the motor kw is sufficient, are there any sprocket or pulley ratios in the drive system that can be changed easily?
Re: Increasing DC Motor RPM
12/08/2010 6:25 PM
"tcmtec" gave very good points regarding this problem.
Check the armature voltage as it is much responsible for speed.
0.7 to 0.9 is not a small variation. Check the mechanical side i-e Gear unit. Check the variation in current.
(It seems that 75 KW motor is for Barring device but for barring pupose 1.2 RPM are very high. Normally in modern Plant it is done at 0.2 RPM).
What is the nominal speed of the Kiln (At rated Feed)?
12/08/2010 11:28 PM
Send us your kiln design and let us see perhaps we can see what is the problem.
Good Answers: 116
12/10/2010 1:55 PM
It may seem a basic point, but no one has written "Multiply the (normal kiln operation) motor ampere reading at the starter panel by the supply voltage reading at the starter panel. If it much exceeds 75000 x 1.1 = 82500 watts we may be talking motor overload here (particularly if the rated rpm is 1.35 at the kiln and you only get 0.9). You may have to tell the production department that overloading the kiln to increase production, leading to motor failure, ends up with zero production - until the motor is repaired. If the power is well below 75000 watts, the shunt field may be getting full volts which gives minimum motor speed, lowest mechanical load on the motor and so reduced electrical input.
Measuring voltage at the motor itself , comparing with supply voltage, will indicate if resistors in the panel are limiting its current.
12/12/2010 10:38 AM
Problem Does't seems to look on the motor side
Actually there will be coating inside the Kiln which makes the speed variation. In drives using DTC(Induction motors) this problem can easily noticed by noticing the torque variation for one revolution on the display of the drive.
As there is coating in the kiln, more power is required to move the kiln as one weight of material (Feed )and second weight (coating in the Kiln)
67model (1); Aghvel Niazi (2); Anonymous Poster (3); PWSlack (1); tcmtech (1); Tornado (1)
