Previous in Forum: Summing Up the Mix Connected Load   Next in Forum: How to Distribute Loads on DB
PLC Panel Testing
12/13/2010 6:47 AM
Burn test for 48 hrs & surge withstand tests are realy appliacable for PLC Panel?
Anand Kathale
Re: PLC Panel testing
12/13/2010 8:04 AM
Surely you don't expect much of an answer to a question with so little detail, do you?
The obvious answer is yes--is there some reason you'd argue that they shouldn't be tested that way?
Good Answers: 181
Re: PLC Panel Testing
12/13/2010 11:14 AM
If you really want to know how to test a PLC panel read this http://www.barn.org/FILES/historyofplc.html The History of the PLC as told to Howard Hendricks by Dick Morley, Dick was the father of the PLC.
I've worked on some of his early stuff, it was built like a tank.
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
12/13/2010 1:52 PM
Thanks Tony, would love to see photos of them too. The auto-pilots in the B52's were analog with tubes, E2 1966, i suppose they were PLC's in a way
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
Good Answers: 181
12/13/2010 3:46 PM
There were no tubes (valves in the UK) in any of the Modicon PLC's, just 3 massive cards. I once tried to make one good unit out of two failed units. I gave up! The first ones I worked with were the 384, the programming panel weighed over 70lb, nice and portable to carry around the plant. Texas Instruments used the same type of programmer, I fell down a flight of stairs carrying one, afterwards I just plugged it in and used it. As I said "built like tanks"
02/08/2011 6:58 PM
Well, a PLC panel is supposed to be turned on all the time, so it's difficult to see what a 48-hour test would achieve.
kwcharlie (1); PWSlack (1); rhkramer (1); TonyS (2)
