Hi friends
i was searching for an answer to the problem we are currently facing onboard our ship these days when i came across this website. It would be very helpful if any of you electrical guys can explain to me whats going on here on the ship.
Problem description:
We have 3 Daihatsu DK 20 generators. 490 KW 60 hertz 720 rpm
here is the scenario:
Suppose #3 is running and the load is 200 KW.
Now we want to take either #2 or #1 on load.I start the generator #1 or 2 and press auto synchro button.The ACB closes and the generator (1 or 2) comes on load. slowly #3 sheds load while #1 or 2 takes on load.
Now here is the problem- Sometimes #1 or #2 would stop taking load after reaching around 100 KW.We have noticed that this happens when both generators are around 100 KW mark. Normally our load is around 200 KW. I have noticed that this only happens with #1 or #2 when no. 3 is already running.
However, the incoming generator`s governor actuator keeps turning in the fast direction and hence goes on increasing the fuel rack till the fuel rack reaches maximum
The #3 load reading remains stuck on 100KW . ( I dont understand why #3 generator is not shedding load when the other generator`s fuel rack reaches maximum.)
Last time ths happened, I was taking #1 on load, Both generators got stuck at around 100 KW each. The fuel rack of #1 kept on increasing till it reached maximum.
I went to #3 and manually turned the knob that is provided as an alternative for the governor actuator motor. it was stuck, neither moving in fast nor slow direction. I moved it in the slow direction and the moment it got free, the knob started turning in the fast direction, i.e the governor actuator motor started turning in the fast direction ( clockwise- fast and anticlockwise - slow)
When I reached the control room I saw that #1 had shed most of its load n was now sharing 50 kw while # 3 was sharing 150 kw.
Now clearly the problem is that the governor of #3 is getting stuck somehow at 100 kw. and when it gets stuck the other incoming generator`s governot actuator goes on giving it a signal in the fuel increase direction till the fuel rack reaches max.
But then why doesn`t the KW reading of the incoming generator increase?
Can any1 help me with this one?
Thanking U in advance
Abhi
Abhinav. :)
