Previous in Forum: DG Set Output Kilowatt   Next in Forum: ct
19 comments
current carrying capacity of copper & alluminium cable
12/14/2010 4:08 AM
sir,
can you please provide me the details of current carrying capacity of copper and alluminium cables.
1. 1.5sqmm*4core armoured copper cable
2. 4 sqmm*4core armoured copper cable
3.10sqmm s/c multistand copper flexible cable
3. 10 sqmm*4core armoured alluminium cable
5. 16sqsqmm*4core armoured alluminium cable
please send me as soon as possible.
thanks
Re: current carrying capacity of copper & alluminium cable
12/14/2010 4:42 AM
Dear Guest,
Have you ever heard of search engines like Google ? Use them & we
request you not to give us any Home work ( on your behalf).
Manrop.chennai.
12/14/2010 4:44 AM
→ British Standard 7671.
12/14/2010 6:46 AM
manrop
if u r too busy then dont look this site..refrain from making garbge comnts..qtns may be silly but nt the answrs as members of different experience levels r partcptng here...plz also dont gve any reference of stndrd as it is also meannglss..
Reply Off Topic (Score 3)
12/14/2010 7:02 AM
There seems to be a problem with several keys on that paricular keyboard. A keyboard change is the recommended couse of action.
12/14/2010 9:09 AM
You Nailed him....
12/14/2010 1:19 PM
Guest,
You seem to be a little testy this morning. By the way, your spelling is atrocious, as are your manners.
atrocious - exceptionally bad or displeasing; "atrocious taste"; "abominable workmanship"; "an awful voice"; "dreadful manners"; "a painful performance"; "terrible handwriting"; "an unspeakable odor came sweeping into the room"
Have a GREAT day.
12/14/2010 7:51 AM
1) 287 amps.
2) 826 amps.
3) 1275 amps.
4) 729 amps.
5) 1107 amp.
All specs are for 70 degrees C.
12/15/2010 9:00 AM
Did you specify the degree rise? Depending on the insulation, bundling, etc the numbers will vary. For code installations, obviously, follow the code. Are there voltage specifications that have to be met? Lots of questions, not many answers.
12/14/2010 9:29 AM
1. 1.5sqmm*4core armoured copper cable - 4000A
2. 4 sqmm*4core armoured copper cable - 3500A
3.10sqmm s/c multistand copper flexible cable- 2500A
3. 10 sqmm*4core armoured alluminium cable - 3000A
5. 16sqsqmm*4core armoured alluminium cable- 1000A
12/15/2010 2:06 AM
In Your Dreams Mate.
12/14/2010 10:23 AM
1. = 5A
2. = 4A
3. = 3A
4. = 2A
5. = 1A
12/14/2010 11:02 AM
Check out these charts! What you want is half way down the page!
Re: current carrying capacity of copper & aluminium cable
12/14/2010 1:03 PM
I love the way this question continues to appear. You can do a Google search to get a referral there or if you must get an answer here you can try the Search CR4 option.
The thing that makes me laugh about this is that everyone assumes that the current will be constant. There really is no current limit these wire dimensions have if one uses a brief pulse and if you do not care if the wire survives for a second pulse. Coin shrinking is one example of this. For those who want to see a video, here is another group. In the high speed video you'll see that the current flows through the coil and shrinks the coin before the wire vaporizes.
12/14/2010 4:32 PM
1. = 5A/1A
2. = 4A/2A
3. = 3A/3A
4. = 2A/4A
5. = 1A/5A
12/15/2010 7:23 AM
It depends upon the insulation,amb temp,method of laying etc
pnaban
12/15/2010 9:58 AM
It looks you are beginner/learning,first thing you are not specified method of installation,ambient temperature etc.for this small size cables u better to refer
cable manufacturer catalogue u will get all the details and apply diversity factor based on your country/region.
12/15/2010 10:51 AM
method of installation :- GI cable tray under raised floor.
ambient temperature:- 5 deg C.
diversity factor:- 0.04
Now what??..
12/16/2010 8:47 AM
ambient 5 deg c you are using in which country,it seems joking.
12/16/2010 5:18 PM
Iceland......please give me answer as you promised.
Reply to Forum Thread 19 comments
Anonymous Poster (10); Brave Sir Robin (1); lyn (1); manroop (1); Mr. Truman Brain (1); pnaban (1); PWSlack (2); redfred (1); vikiinuk (1)
