Previous in Forum: Star / Delta O/L’s - Which is Correct   Next in Forum: What is Compensated Network? Isolated Network?
9 comments
Generator Bracket
12/15/2010 5:32 AM
Will the height of upper and lower bracket of a generator be same? If not how will be different?
Good Answers: 181
Re: Generator Bracket
12/15/2010 6:07 AM
The height of the upper bracket will be 4m above the lower, so the difference will be 4m.
Try re-phasing your question, you may get a sensible answer.
12/15/2010 6:22 AM
Er, will the lower bracket be above the upper bracket, then? Curious minds want to know.
Good Answers: 181
12/15/2010 6:34 AM
Can't be, otherwise all the electricity would fall out of the generator
12/15/2010 6:43 AM
If a 24V filament lamp were to be connected....oh, never mind.
12/15/2010 7:52 AM
Height is same. if not, difference will be in length. You can measure it in cm,inches, feet,furlong etc.
Good Answers: 181
12/15/2010 8:20 AM
If it were the same the generator would be on it's side, the electricity would be sloshing around inside, I suppose then the electricity will flow along the "length" of the cables
12/15/2010 10:42 AM
Absolutely right.....GA
Good Answers: 116
12/15/2010 10:59 AM
Generators expect the shaft to be horizontal, usually. Less often, shaft is vertical. Must be installed to ensure angle is exact.
India - Member - New Member
Good Answers: 164
12/15/2010 11:08 AM
67model (1); Anonymous Poster (2); kvsridhar (1); PWSlack (2); TonyS (3)
