Previous in Forum: Moment   Next in Forum: Axial Flow Fan
3" Pressure Reducing Valve Capable for Use with Saltwater
12/19/2010 4:17 PM
I need an valve that can reduce water pressure from 12 bar to 5 bar. This valve must be resistance against saltwater.
Anybody that can help me with brand name and type of valve?
Re: 3" Pressure reducing valve capable for use with saltwater
12/19/2010 4:31 PM
Common terms are "pressure reducing valve" or "pressure regulator." If you search these phrases, you can probably find some manufacturers to phone up. Such a valve might not be a common catalog item, so calling around may be necessary.
Re: 3" Pressure Reducing Valve Capable for Use with Saltwater
12/19/2010 10:31 PM
Samson are my personal favorites. Duplex 2507 valve body will prevent chloride corrosion, suggest internals also, although lesser grade likely OK (due to high velocity).
http://www.samson-usa.com/index.htm
These valves are fully controlled to flow or pressure input using a PLC.
Also Flowserve has this valve ...
http://www.flowserve.com/Products/Valves/Control/Globe/VALTEK-FlowTop-HighPerformance-Control-Valve%2Cen_US
Flowserve is excellent company in all things sea water desalination - corrosion should not be an issue.
Alternatively if you simply need static / constant pressure drop, without automated control, then I suggest Tyco (excellent company in all things valves).
http://www.tycoflowcontrol-na.com/products_results.asp?Selection=Globe+Valves&m=1
Good luck. Suggest consulting with the valve manufacturers, with your requirements - ie pressure loss at specific flowarate. Cv calculations aren't the easiest calculations.
12/20/2010 1:06 PM
Thanks for your effort regarding this matter.
Regards
Borge
12/20/2010 2:21 AM
To make a correct choise, you need to know a little more. You want ro reduce salt water pressure, in which quantaties ? and at what tempertures ? Is this salt water ordinary sea water or something else ?, are there solid particals in the water or is the salt copletely desolved ?
If you made your choise in brand, the manufacterer should ask you these questions.
And there a alot more manufacterers as mentioned above.
Only if it's impossible, it will never happen
12/20/2010 5:22 AM
Refer the following link
http://www.metalwork.it/eng/skillair.html
Regards,
Ramaraj.T
01/04/2011 11:05 AM
Yep. It would be an easy one for the local valves distributor to solve over the telephone.
Does anyone use trade directories any more or is it all a bit interwobbly now (rhetorical question)?
04/22/2025 11:32 AM
Most plastics have <...resistance against seawater...>.
Register to Reply 7 comments
ajwinemaker (1); Anonymous Poster (1); bdirdal (1); Henk klep (1); PWSlack (2); Tornado (1)
