Previous in Forum: Identify This Machine   Next in Forum: Home Made Zamboni
8 comments
Lopez galego/vein psv part for pump
12/21/2010 11:08 PM
Dear all,
I am looking for psv spare part of pump named lopez gallego/vein. I don't have much detail information. i only told that is a sparepart of a pump. does it a brand or part? what kind a part is it?
please advise what kind of spare part is it and where can i buy it (the supplier or manufacture)? if you know, please also advise the detail information about the spare part.
I really need your advice ASAP since i've been browse for 2 days and haven't find it yet..
I really appreciate your kindly fast reply and while thank you for your reply.
Best regads,
Hetty
PT. Duta Champion Utama
Jakarta - Indonesia
Canada - Member - New Member
Re: Lopez galego/vein psv part for pump
12/22/2010 1:14 AM
Are you sure that the pump's name is 'lopez gallego/vein"? As I'm sure that, as you have so far explained, that Gooooogle does not provide a concise answer to that request.
Please check your info again, and let us know how you made out! - Loupy.
Also, what does 'psv' stand for - as it may be a fairly standard part that may be interchangable with parts from other manufacturers.
Have a Happy! ;-)
12/22/2010 1:41 AM
A search regarding the acronyn 'psv' revealed a 'pressure safety valve' description, - are we narrowing in on to your request, hetty? And if this is the case, what is the pressure release set at? and what size and type of pipe/hose? - Loupy.
Have a Happy! ;-)
12/22/2010 1:57 AM
from the data which i got from google, the explanation about psv is pressure safety valve and safety relief valve engineering, you are right. But, i can't find about lopez galego/vein whether it is a brand or a name of a part. since i only found it as medical part. but that isn't what i'm looking for. first, i thought it's a valve but i can't figure what kind of valve is it. but i'm sure it's not a pump name, because i have search also and didn't find a pump named lopez galego.
i don't have information about what is the pressure release set at. what i knew is this is one of the sparepart of PSV for a pump...
thank you.. (Hetty)
12/22/2010 6:23 PM
There is a Spanish company, Talleres Lopez-Gallego, that appears to make pumps and valves. The PSV makes sense as pressure safety valve. I wonder if you mean "vane" instead of "vein"; vane type pumps are commonly used in hydraulics.
12/22/2010 9:32 PM
Thank you so much for your helpful information...
I will find out what kind of part which is fullfil my need...
12/22/2010 9:47 PM
By the way, "taller" (plural "talleres") means workshop or studio in Spanish, akin to "atelier" in French. The double ll is pronounced in Spanish as a strong y.
If I have guessed correctly, the pressure safety valve on your pump would be a part that could experience wear and then begin to leak. Thus it would be a logical spare to have on hand.
12/22/2010 10:15 PM
Do you have any information such as contact person or email or website of this company? So i can start to contact them...
Thank you..
12/23/2010 7:49 PM
Some really good detective workings on Goooogle! you must have more patience than moi! - GA - Loupy. (I hope that our help gets the poster on the right track to solving his dilemna!) - seems that's he's working with absolutely minimum info provided to him - (probably offshore).
Have a Happy! ;-)
Register to Reply 8 comments
hetty (3); Loupy (3); Tornado (2)
