Previous in Forum: Seismic Anchorage   Next in Forum: House Insulation Issues
12 comments
Bouyant Force of Wet Concrete
12/27/2010 10:29 AM
if the typical unit weight of concrete (150pcf) is used in calculating the bouyant force on a submerged pipe in wet concrete, what then is the buoyant force on a single sand particle or stone particle or cement particle in water (which together all make up the unit weight of concrete)?
Re: bouyant force of wet concrete
12/27/2010 10:40 AM
Google
Good Answers: 58
Re: Bouyant Force of Wet Concrete
12/27/2010 11:25 AM
One of my favorite books is my 'pocket reference', it has just everything in it. I got it at Ace Hardware, it's by Thomas J. Glover.
It shows water @ 62.4 lbs./cubic foot
dry sand @ 100 lbs./cubic foot
crushed stone @ 100 lbs. cubic foot
portland cement @ 94 lbs. cubic foot
Now you still have to work out the proportions to get the actual buoyancy.
mike k
12/27/2010 11:41 AM
I think it's homework, but, you are right about the Pocket Ref.
It's without a doubt the best $10.000USD book I've ever owned.
If it isn't in that book, you don't need to know it!
Good Answers: 74
12/29/2010 2:04 PM
The buoyant force on any particle submerged in water is 62.4*V where V is its volume in cubic feet. Concrete has nothing to do with the question posed.
Bruce
01/06/2011 4:08 PM
Can you answer this question?
Say you have a 54" Diameter Concrete pipe .
Encased in a 6'x6' form. How much uplift force can you expect?
Good Answers: 74
01/07/2011 12:46 AM
The answer to your question is...yes, I can answer your question. A 54" dia. concrete pipe encased in a 6'x6' form would have no uplift at all by simply being encased in a form. If the form is subsequently filled with a liquid, the uplift force on the pipe would be the weight of the liquid displaced by the pipe.
If the liquid placed in the form is cast-in-place concrete, the uplift force would depend on the speed of placement. As you all know, cast-in-place concrete does not remain liquid for very long. If the placement is slow enough, there may be minimal uplift on the pipe, but if the placement is very rapid, the uplift force could be as high as 150V where V is the volume of the pipe in cubic feet.
Bruce
Re: Buoyant Force of Wet Concrete
01/07/2011 12:18 AM
The particles are not submerged in water. They are in a cement and aggregate slurry with an effective density of 145 lbs/cubic foot.
Therefore any object that you are trying to encase in concrete would have a buoyant force of 145*V where V is the volume of the object.
kdelta
Good Answers: 74
01/07/2011 12:56 AM
Read the bloody OP. The particle IS submerged in water.
Bruce
01/07/2011 3:40 AM
I did read the OP and my response was basically the same as your post #8 except that I did not delve into the rate of pour issue. I point out that all concrete is usually vibrated which will result in the full liquid head acting on the submerged element during vibration no matter what the rate of pour is.
The OP asks about the buoyant force on the particles which are in wet concrete. These particles are not submerged in water. They are coated with a water and cement mixture. If they were truly submerged then hey would behave more like a layer of sand and gravel in the bottom of a bucket filled with water. If the buoyant force on the particles was only that due to water then all the sand and gravel would immediately settle to the bottom since its density is much higher than water and the cement paste would flow away.
kdelta
Good Answers: 74
01/07/2011 2:51 PM
Not the way I read it. He is asking about the buoyant force on a single sand particle or stone particle or cement particle IN WATER.
If he means to ask about the buoyant force on a single sand particle or stone particle contained within a concrete mix, then I guess I agree with your interpretation. I'm not sure that you are correct, however in the case of a single cement particle as cement has a lower density than concrete. How would a chunk of course aggregate affect the buoyant force on a cement particle? I believe other forces are at work within the cement paste between chunks of aggregate.
Bruce
Good Answers: 130
01/07/2011 7:28 PM
"If the buoyant force on the particles was only that due to water then all the sand and gravel would immediately settle to the bottom since its density is much higher than water and the cement paste would flow away".
But cement is not less dense that water
(see post #2)
01/03/2011 12:05 AM
What Bruce mentioned is the way to go
34point5 (1); Anonymous Poster (2); ba/ael (4); kdelta (2); lyn (2); mike k (1)
