Previous in Forum: Weight of ms channel,ms i beam,ms angle   Next in Forum: How to Design a Coupling
Tapping in Blind Flange
12/28/2010 4:01 AM
Hi All,
I have to do tapping on 1" blind flange. I want to know what is the maximum size of the tapping I can go in 1" blind flange( i know i have the option of reducing threaded flange).
Any help would be appreciated but it shall be in reference to some code or standard where i can find the same.
Thanks.
Pathfinder Tags: Blind Flange Tapping
Re: Tapping in Blind Flange
12/28/2010 4:24 AM
I doubt that anything greater than 1" female pipe thread would be useful, and I bet that 1/2" fpt would be plenty.
12/28/2010 10:36 PM
Try with lesser to max diameter taps which decrease the machining(tapping) load which is easy for tapping more depth
Good Answers: 120
12/28/2010 11:47 PM
I have seen sets of progressive taps used for this purpose. The first one taps in and bottoms....clean it out, next one and the final one that cuts to the bottom of the hole. I believe you need to clean often. A machinery handbook should deal with this. You may need a locknut, cotter or wire for securing it.
Per Ardua Ad Astra
12/29/2010 11:10 AM
I prefer to use half coupling with NPS 1" socket welded or NPT (threaded) to be welded into the blind flange, and try to avoid threading directly into blind flange.
12/30/2010 2:30 AM
Thanks to all for their valuable reply.
Actually we had tapped 1" hole in 1" blind flange, i know thats is quite unusual. Fuhrer we had used a BOSS for reinforcement (pls refer para 6.12.1 ASME B16.5 for reinforcement requirement of threads).
I was wondering if someone had the similar experience ?????
Thanks.
Abdel Halim Galala (1); Anonymous Poster (1); aurizon (1); Material_Pipe (1); Tornado (1)
