Previous in Forum: Dual Voltage 3 Phase AC Generator   Next in Forum: Torque Requirements
Breaking and Making Time of Breaker
12/29/2010 1:21 PM
why is breaking time less than making time of breaker?
Good Answers: 804
Re: breaking and making time of breaker
12/29/2010 1:29 PM
It is? What are you looking at?
"Breaker"
"Breaker"
"Breaker"
"Breaker"
12/29/2010 1:48 PM
I want to know why the breaking time of a contactor/breaker is less than the making time of the same?
01/02/2011 6:55 PM
So does verma.707.
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Re: Breaking and Making Time of Breaker
01/02/2011 2:17 AM
Breaking the circuit is difficult than making close. Because energy is flowing through the circuit and due to curent flow some energy is stored as magnetic field. At the time of breaking this energy will converted into capacitance and there will appear high voltage across the poles. Again there will be a tendency to continue the current flow via arcing. So breaker should act fatly to avoid this continuation of the arcing and there should be enough methods to vanish this arc.
But in case of closing such a problem will not comes.
So breaking should be faster.
If you can't find a way, make one........
Good Answers: 130
01/02/2011 2:23 AM
You realise you have completely contradicted yourself.
Good Answers: 130
01/02/2011 2:28 AM
It's simple mechanics.
For a contact to 'fall away' from contact is 'zero distance' (given an ac half cycle '0' V handy, conduction ceases)
For a contact to 'contact', it has to travel a longer distance.
Spring rates and magnetic collapse do have an effect, but generally distance is the larger factor.
Register to Reply 6 comments
34point5 (2); Anonymous Poster (1); JRaef (1); justinanto1987 (1); PWSlack (1)
