hi all,
would you please help me to understand this,
i understand that when i change connection from high to low ''380v to 220v'' on 3 phase dual voltage ac generator, i am making two coils on parallel between each two lines, so they will be two ac 3 phase generators running on parallel excited from the same rotor, and when i connect to high i am making each two coils on series between two lines, thats on dual voltages 6 coils ac generator.
so if its 200kva generator: when its connect on high it can carry 300amps, while when its connected on low it can carry 600amps.
how about when its dual voltage generator with 3 coils only, i mean when its on high it will be star connection while when its on low it will be delta connection, will the amps be different while its on high and low? because when its on high, two coils will be on series. while on low, one coil will be between two line voltages.
hope you got what i mean
thanks
