This is a new concept for me, but i want to explore it , perhaps it can be adapted to other uses.
This concept is to use (several uses) flexible water containers, called water pillows.
This concept could be adapted to emergency housing and not so emergency housing, also can be adapted to marine.
Heavy "anyway" stuff is to have secondary uses. I did some houses lifting in the past and i can see a house or a boat sitting on a water pillow, ie producing a flow of water pumping (less) and pushing at an interesting rate. The flow of water can be used for pushing radiant heating into a water piping grid (what i have at home) from a PT (Pillow Tank) transfer to another PT. For a house, the differential height will be compensated my a hinged handicaped ramp.
The flow can generate a vacuum for boiling water (possibly making potable water) , and /or use a reverse osmosis membrane system, for water quality control.
The main objective of this question is what flow of water do i need for a mini hydro turbine, we are comparing this system to photovoltaic. New high tensile materials make this possible for PT resistance. The Tesla turbine is not out of the question yet, a hybrid wind and water system is considered also. A steam (parabolic sunlight concentrator ) add on is not out yet but that would be for a stationnary set up.
Thank you for your help.
