As a result of recent arc flash studies we have modified our switching procedures to facilitate dead-bus racking of 480V station service main bus breakers and 13.8KV generator breakers. Two of our powerhouses, however, have SF6 generator breakers which are unrackable but are equipped with NLB disconnect switches on either side of the breakers. Each phase of the switches is in its own metal enclosure and is separated from the other two phases. They are manually gang-operated by a hand crank external to the enclosure. We currently operate the switches deenergized but are questioning if this is necessary with respect to arc flash hazard.
If my understanding is correct, an arc flash hazard exists where there is the possibility of phase-to-phase contact. This might imply that, since each phase of the disconnect switches is separated from the other two phases with no possibility of phase-to-phase contact, there is not a risk of an arc flash event during switch operation. While we would like to operate the switches energized, I am not willing to change our procedure based on an implication. I hope someone can point me toward information to determine whether or not there is an arc flash hazard while operating the switches energized.
Additionally, the disconnect switches are designed to be operated energized but the manufacturer cannot take a stance one way or the other on the subject of arc flash.
