Previous in Forum: Arc Flash Hazard   Next in Forum: Simple 4-20mA Generator
Protection Relay Test Protection
12/29/2010 9:50 PM
Can anyone advise - Inquiry for protection relay test system with specification as below:
3.EnclosureHigh Impact, Molded, Flame Retardant and Immune to severe shock and vibration
4.Line Power Supply210-260 VAC, 60 Hz, 1Æ, 3-wire
5.Operating Temperature0° to 50°C
6.Storage Temperature-25°C to +70°C
7.HumidityUp to 95% relative humidity non-condensing
8.Electrostatic Discharge ImmunityCapable for
IEC 801-2
9.Surge Withstand CapabilityCapable for ANSI/IEEE C37.90
Basic Requirements and Operating Parameters for PRTS
10.AC Amplitude Accuracy at 50/60 Hz Voltage and Current Sources
< 0.1% of reading
Total Harmonic Distortion
< 0.1%
11.AC Amplitude Accuracy at 50/60 Hz Convertible Sources in Current Mode
< 0.2% of reading
< 0.2%
Phase Angle of Voltage and Current Sources
a. Range0° to
+ 359.9° (lead/lag)
b. Resolution+ 0.1°
c. Accuracy+ 0.5° at 50/60 Hz for Convertible Sources in Current Mode
+ 0.25° at 50/60 Hz for Voltage and Current Source
Frequency
a. RangeFrom 0.1 Hz to 2 kHz at full power continuous load or better
b. Resolution0.001 or better
c. Accuracy0.5 ppm typical
Other Technical Requirements
The PRTS shall be provided with a controller with the following minimum technical requirements.
PRTS Controller
a. TypePC compatible
Notebook Computer
b. Hardware
1. ProcessorPentium IV or latest model available
2. RAM Capacity256 MB RAM
3. Clock Frequencylatest available
4. Hard Disk Capacity
> 20 GB
5. Video Card Capacity, M bytesLargest available
6. Monitor14.0" TFT color matrix monitor
User-tagged by 1 user
Re: Protection Relay Test Protection
12/29/2010 10:36 PM
I am not sure but I do remember seeing relay documentation on the Maintenance Geeks Download section. You could try there. If not you could email them I know that they are always adding to the download area. They may have it just not yet uploaded. I know I was looking for information on transfer switches and it was not yet in the download section but I posted on the forum and it was uploaded the next day. Just a suggestion.
12/30/2010 5:48 AM
try to use Omicron test equipment
Good Answers: 131
12/31/2010 5:33 PM
You could also look at equipment produced by Doble Engineering and Megger. Both of them have been in the test equipment business for a long time.
Register to Reply 3 comments
Anonymous Poster (1); dj46 (1); PeterT (1)
