Previous in Forum: Barber Chairs Won't Stay Up   Next in Forum: Electric Farm Tractor Development
19 comments
India - Member - New Member
Gear Box - Conveyor Length
12/31/2010 12:05 AM
Does Conveyor length will differ the load on the gearbox ?
When Emotions runs high ,Intellectual wont work
Re: Gear box
12/31/2010 12:16 AM
Yes.
Re: Gear box
01/03/2011 10:30 PM
Is there any formulae for calculating gear box out put torque which include conveyor length & width.
Re: Gear box
01/03/2011 10:42 PM
T = L W H ρ r (c.f.) (s.f.), where:
T = torque
L = length
W = width
H = height of product
ρ = density of product
r = radius of belt over drive pulley
c.f. = coefficient of friction of belt on conveyor bed
s.f. = service or safety factor
Re: Gear box
01/03/2011 11:04 PM
In this Gear box output rpm will invloves or not ? I didn't understand about Heigth , density of product , service factor and coefficient of friction of belt
Pl find the details of gear box and conveyor we are using & pl suggest to calculate torque.
Geared motor details:
Power - 4 Kw
Out put rpm - 60.9 rpm
Conveyor length - 13.5 meters (1350 mm).
Conveyor width - 900 mm
Re: Gear box
01/03/2011 11:55 PM
Calculating from the input power direction, P = K T N, where:
P = power
K = constant depending on what units of measurement are being used
T = torque
N = revolutions per minute
(I don't regularly do SI units, so I forget what K is. Sorry.)
Unless this conveyor is loaded with gold bullion, the motor is probably enough, but I don't know about the gearbox.
Re: Gear box
01/04/2011 12:28 AM
Sorry, i didnt get you . pl clarify me clearly.
Re: Gear box
01/24/2012 12:32 AM
What would the coefficient of the friction between the Canvas belt and rubber roller.
Density of the product means whether for belt or rubber roller ? What is service factor?
Re: Gear box
01/24/2012 12:42 AM
That shouldn't matter; the belt is not supposed to slide on the roller.
Density of product refers to the stuff being conveyed, not to the belt or rollers (although the weight of the belt is a minor consideration.)
Re: Gear box
12/29/2012 9:38 AM
Density of product means whether the product which is being transferred or the belt. And Coefficient of friction between the drive roller & belt or Conveyor & the belt.
Pl clarify
Nithin
Re: Gear box
12/31/2010 12:17 AM
Generally yes, unless maybe it is running downhill.
Re: Gear box
12/31/2010 3:42 AM
A very simple tool for answering such questions yourself is to simply consider the two extremes.
What is the load of a zero length conveyor belt?
What is the load of an infinitely long conveyor belt?
Are they the same?
Re: Gear box
12/31/2010 9:42 AM
Not so fast, nocksman. " zero length conveyor belt" would be an oxymoron. Or at least a contradiction of terms.
Re: Gear box
12/31/2010 10:19 AM
Now you just run along to the end of the infinitely long conveyor belt where there's a nice present waiting for you...
Re: Gear box
12/31/2010 12:12 PM
Ya know, that was a mean trick. The second time I stopped to rest, I asked someone how far to the end. He said "you can't get there from here."
Re: Gear box
12/31/2010 12:40 PM
No, no, I meant the other end .
Re: Gear box
01/03/2011 3:43 AM
It's good to know that the silliness that prevailed during 2010 has enough momentum to keep going through 2011...
Re: Gear box
01/03/2011 3:48 AM
Okay, let's yank Lyn's chain and make and make him run back to the zero end.
Wasn't there a movie about this: Up the Down Staircase?
Re: Gear Box - Conveyor Length
01/04/2011 12:49 AM
Hey, coach, it's 4th down and 120 yards to go; can I punt?
Good Answers: 130
01/04/2011 3:02 AM
I would have about 'what has payload got to do with it'.
But I am very much admiring your patience
Register to Reply 19 comments
34point5 (1); lyn (3); P.Nithin Kumar (5); PWSlack (1); Tornado (6); user-deleted-1105 (3)
