Currently we installed a new printer Tally T2240 9 to print events online but it failed to work. This printer is connected to an advant station 500 from ABB. In the advant station printer setups it indicates that it is sending signals to the printer but the printer is not responding. the printer is connected to the Advant via a serial connection. the printer also has a parallel port and when conected to the advant through the parallel port it dose print but since it is not designed to print that way it prints some un-understandable characters.If you measur at the printer serial cable from the printer there is some voltage present.
