Previous in Forum: ABB MAKE SPAJ 140C RELAY FOR 20 MVA 16.5kV/6.9kV TRANSFORMER   Next in Forum: DG Set Rental Service
10 comments
Power Factor.
01/01/2011 11:05 AM
Dear friends.
How I can calculate the capacity of the required capacitors that should installed with anew over head line having the following data.
1-The HV side is (11KV) and LV is (0.4KV).
2-The feeder have 16 over head distribution transformers with capacity of 400KVA and 4 transformers with capacity of 250KVA.
3-The feeder connected to the substation by under ground cable (1x150) with a length of 1500 meter.
4- Total feeder length is 35km.
5-Some of the customers are normal houses while the others using (380V three phase motors) in water pumping stations white different capacities ( max.35hp approximately)..
Hope to get guidance from all expert here.
Re: Power Factor.
01/01/2011 10:41 PM
calculate the PF in live state and find the reactive power required for LV side.
Re: Power Factor.
01/01/2011 10:58 PM
You should work out the load factors, diversity factors and the inductive reactance of the transmission line, capacitor assessment is secondary to these.
Knowledge sharing is a WIN-WIN situation
Re: Power Factor.
01/02/2011 2:26 AM
you have to know the exsisting power factor , let us say it is :
cosΦ1
then you have to decide to which power factor you want to improve your system?
let us say cosΦ2 then the required capacitor measure in Kvar is :
Q= P (tanΦ1-tanΦ2) where :
P is the active power and P=sqr root 3*VIcosΦ1
hope it works.
Re: Power Factor.
01/02/2011 9:49 AM
Call a good contractor and record the variation of pf,harmonics,voltage,current,watts,Var etc for a 24hr period and give a contract to a Capacitor bank manufacturer. Alternatively you may install cap banks for each feeder
pnaban
Re: Power Factor.
01/02/2011 10:14 AM
We are contractors and I am assigned for this job. please help me. Otherwise I will be out from job
Regards
Noorirm
Re: Power Factor.
01/02/2011 10:51 AM
Give a sub contract
pnaban
Re: Power Factor.
01/02/2011 6:31 PM
So the firm has sold something that it cannot supply? Outrageous! It sounds like everyone needs to be out of a job!
Good Answers: 44
Re: Power Factor.
01/03/2011 11:18 AM
You said it brother!
Re: Power Factor.
01/04/2011 9:21 PM
generally speaking...use the over all power factor of the system..not based on individual loads but of the sending end side...employ power factor correction by the use of your capacitor banks...this time instead of using a huge/bulk capacitor employ the much lower kvar ratings..this is to allow you to choose the range of your pf correction by simply the employment of switching mechanism..afterall, a waste KVAR is still a load loss..
take care of your seconds and the minute will take care of itself..
Good Answers: 116
Re: Power Factor.
01/02/2011 3:41 PM
  1. We must get on the right path!!
  2. What do you expect the capacitors to do??
  3. I can think of two purposes for capacitors, power factor correction and as part of voltage surge arrestors. Is it either of those? Power factor correction is usually the consumer's problem.
  4. Who thinks capacitors are needed, is he technical? Did he give a purpose for them?
Register to Reply 10 comments
67model (1); Anonymous Poster (2); baghdadi (1); cuba_pete (1); mountk2 (1); pnaban (2); PWSlack (1); rockraiden (1)
