Previous in Forum: Need Fluent Software   Next in Forum: Image Processing Software
LG Monitor Problem
01/02/2011 11:36 PM
whenever i start PC my 17" CRT(LG SXGA700E) monitor led blinks very fast and gives clicking sound but nothing displys . The blinking slower gradualy and after 25 minutes it displays menu. why it is take so long time to display ? How can i get it repaired
Good Answers: 119
Re: lg monitor problem
01/02/2011 11:51 PM
My 9 year old 17" CRT had similar problems. I discarded it and found a 19" HP LCD (4:3, used, in nearly perfect condition) at a local computer recycler for just under $40. Local repair shops around here won't even "look" at an item for $40. You should check for computer recyclers in your area. You might be pleasantly surprised.
01/03/2011 8:21 AM
If the clicking sounds only lasts for a few seconds, it is probably due to the de-gaussing circuitry, which pulses a coil near the screen to eliminate any residual magnetism in the shadow-mask that would cause color impurities in the picture.
If it's taking 25 minutes for the picture to appear there is a problem with the CRT filament or the circuitry that drives the filament. If there is a TV repair shop anywhere near you, they might be able to test it/fix it. You could try adjusting the black level setting ('brightness level') if there is a knob-adjustment or menu selection for it; otherwise there might be an potentiometer adjustment for it on the high voltage power supply which would likely require that you open the chassis in order to gain access to it.
Re: LG Monitor Problem
01/03/2011 11:12 AM
Either:
1. Leave it on all the time
2. Pitch it in the recycle bin and buy a new monitor.
3. You can't get it repaired anyway. It's too old.
4. Pitch it in the recycle bin and buy a new monitor.
5. Pitch it in the recycle bin and buy a new monitor. You can't get it repaired anyway. It's too old.
6. Pitch it in the recycle bin and buy a new monitor. You can't get it repaired anyway. It's too old.
lyn (1); mjb1962853 (1); Usbport (1)
