Previous in Forum: Bench Set   Next in Forum: Gas flow , bunrer basic , digarams
Temperature Device
01/06/2011 7:24 AM
i'm doing a mini-project on Automatic heat dissipation control in hot plates using fan.what is the best temperature Transmitter?.The temperature range is 30DegC to 100DegC ??
Re: Temperature Device
01/06/2011 7:26 AM
On the basis of the specification so far? A thermostat.
01/06/2011 7:58 AM
What is the sensitivity of Thermostat???
01/06/2011 10:26 AM
Whatever it says on the spec sheet.
01/06/2011 8:32 AM
Why would you want to cool a hot plate with a fan? Just don't touch it till it cools off.
01/07/2011 10:54 AM
If temperature is not controlled.the device may get damaged...
Good Answers: 116
01/07/2011 12:22 PM
  1. How you make plate HOT, put over camp fire?"Hot plates" are what you cook pizza on!
  2. Blow away flame with fan to control heat?
  3. Heat dissipation and temperature not same thing!
  4. Which do you want automatically controlled, from 3. ?
  5. Insufficient data......
Good Answers: 116
01/06/2011 9:18 AM
A transmitter incorporates an electronic amplifier. They do not like 100 Celsius. Platinum Resistance Detectors (RTD) give best accuracy, with stronger electrical output than thermocouples (TC). But if you want spot temperature or to manually move over surface, thermocouples are much smaller. Look up "temperature sensor" or "temperature measurement" on Wikipedia. For "nuts and bolts" of RTD and TC use I recommend "TC Ltd" guide - www,tc.co.uk.
Register to Reply 7 comments
67model (2); lyn (1); pmani0812 (2); PWSlack (2)
