Previous in Forum: DC Drives 6RA22 Tripped on F05 (Supply Voltage +/-20%)   Next in Forum: Effect of Low Frequency on the Voltage in a Generator
Hard Magnet : Effect Due Cutting Into Two Pieces
01/07/2011 4:15 AM
It is welknown that mechanical impact / heat adversly affect magnetic properties of hard magnet.
In one application, hard magnet of two inch length is required to be cut into 1 inch length.
This hard magnet is used for very simple application of retaining small cover of the enclosure in its maintenace position.
Immediately after making it into two pieces, magnet is still usable for this application.
Due to the mechanical operation of cutting or breaking magnet into two pieces, will the life of magent drastically reduce?
Thanks!
Re: hard magnet : effect due cutting into two pieces
01/07/2011 4:25 AM
You need to run water or oil over the magnet during cutting to keep it cool.
Good Answers: 116
Re: Hard Magnet : Effect Due Cutting Into Two Pieces
01/08/2011 10:03 AM
Good advice from post #1. Good idea to re-magnetize the pieces after cutting. But permanent magnet materials tend to be very hard and difficult to cut. Impact may work better on brittle material. If you want many, buying them at right length is best. If you know what the material is, then information should be available on its long-term retention of magnetic strength and what causes loss. If magnets are cheap-enough for cover retention, chances are good it will be robust material - it is the expensive, high performance materials which are delicate.
You might be interested in: Magnet Wire, Hard Drives, PCMCIA Hard Drive Cards
