Previous in Forum: Hard Magnet : Effect Due Cutting Into Two Pieces   Next in Forum: Surge Arrestor
Effect of Low Frequency on the Voltage in a Generator
01/07/2011 5:54 AM
What will be the effect of frequency Low on the Voltage in a generator
Re: What will be the effect of frequency Low on the Voltage in a generator
01/07/2011 6:11 AM
Eh?
If the generator were not connected to anything, then the low voltage and requency matters not a jot.
The effect on what piece of equipment?
Low speed in the generator is the cause of low frequency. To what is it connected that could affect the system voltage as a result of the low frequency?
01/08/2011 12:47 AM
generator frequency is proportional to your RPM..that is, prime movers rpm - reduction gear - generator rpm (this is for Turbo Gen set-up) or for directly coupled - prime mover rpm = generator rpm... basically does not affect your generator...but as PW slack said..it is your load that is affected... voltage-frequency ratio comes in...
take care of your seconds and the minute will take care of itself..
Good Answers: 116
01/08/2011 4:24 PM
  1. If the field strength is fixed, then voltage is proportional to frequency (at no-load).
  2. But most generators have an automatic voltage regulator, which changes field strength to compensate for both frequency and load effects on voltage.
  3. For example, alternator in a motor car keeps steady (battery) voltage from idle to maximum speed, big public power station generator is rated for nameplate output power with only a few percent variation of voltage and/or frequency.
Register to Reply 3 comments
67model (1); PWSlack (1); rockraiden (1)
