Previous in Forum: VW Diesel and Veg Oil   Next in Forum: 3.3kV Soft-Starter Motor Persistant Problem
Tie Transformer
01/09/2011 8:05 PM
I would like to know the factors that we have to use tie transformer and minimize the sc level.
I think if we want to minimize the short circuit level, we have to use toe transfomer (one of the options).
regards,
rongg
Pathfinder Tags: sc level tie transformer
Re: Tie Transformer
01/10/2011 2:33 PM
Depending on the transformer use and configuration one of the ways to limit short circuit current is by using a neutral earthing resistor (also called a neutral grounding resistor). Fuses and similar protective elements also work well to limit the short circuit duration (and hence the let through I squared T power).
Try a search of CR4 for these terms as they have been discussed many times, alternatively try an internet search.
