Previous in Forum: Inductance Testing Mode   Next in Forum: Mobile Receiver
Wireless 802.11n Range Question
01/11/2011 7:28 AM
I've noticed some "high power USB adaptors 802.11n w/9dBi Hi-Gain Antenna's" that claim range is 1800 meters. I thought max range of 802.11n was up to 250m max. So question is, are these hi-Gain antenna's legal for use in UK?
Pathfinder Tags: 802.11n legal
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Wireless 802.11n Range Question
01/11/2011 9:41 AM
There should be no problem with legality of any mainstream adapter or antenna you can purchase. I would guess the "rules" that apply to wireless adapters are for total RF power output. Some antenna's are better at using this power than others, thus the "hi-gain" claim. You almost always lose directivity as the gain increases, meaning, you will need to aim or orient the antenna towards the source for best results. With very tight directivity of antenna's, you can get much more than 1,800 mtrs. Check out the Can-tenna on Wikipedia. If you pointed two "cantennas" at each other very accurately, you could probably get some pretty impressive range. There are some that actually make a sport of this, seeing how far they can establish a wireless link.
Tom D.
Good Answers: 60
01/11/2011 8:04 PM
If you were to connect a high gain Ariel up to your USB, it is feasible to transmit several miles.
Ariels are not governed by any regulations, only the power output of the units.
The gain of the Ariel is a function of its ability to concentrate the Radio waves.
For example, an omni directional has no gain as the power goes everywhere. If you add a reflector to the omni then some of the power goes in one direction. This Ariel now has gain, and the more reflectors and directors you add the more the power output is concentrated in one direction and thus more gain (simple explanation).
Register to Reply 2 comments
You might be interested in: Antenna Mounts, Horn Antennas, Chip Antennas
