Previous in Forum: Directional Valve With Function Counterbalace Valve ?   Next in Forum: Helicopter Cruising Force
Good Answers: 22
Spline Description
01/11/2011 8:52 PM
Hello everyone,
I am trying to understand how to translate the following description from a European manufacturer into US terms. I have looked in my Machinery's Handbooks to no avail.
"Hollow shaft spline 55/65 L:175 (DIN 5481)"
Can someone please enlighten me?
Thanks
Re: Spline Description
01/11/2011 9:50 PM
Here may be part of the answer: http://www.omnigear.us/5481InvoluteSplines.aspx
Unfortunately, not all the numbers match up. For your 55/65, I'm not sure whether those are diameters, serration counts, or included angle of serration form. The L:175 seems like a length. DIN5481 is the standard specifying the "tooth" form.
Good Answers: 22
01/11/2011 10:58 PM
Thanks Tornado,
I had looked at that site as well and drew the same conclusion you did.
01/12/2011 9:30 AM
Just a few cautions, not all directly to your issue.
30 years ago I was involved in a project in which we bought a continuous caster (for a steel mill) from an Austrian firm. We learned some things the hard way (hopefully things are better today):
  • Metric threads (for screw fasteners) are not (a single) standard--at the very least, we ran into German metric threads and Japanese metric threads which were not compatible.
  • We asked our supplier to provide us with (maintenance) drawings converted to English measurements so we could do repairs in local (American) shops. A big problem was the tolerances--when machined to the English dimensions with English tolerances, we often found that parts would not fit. (Minor rounding off and so forth led to the problem, iiuc--I was an electrical / process control engineer on the project--the mechanical engineers had the big headaches.)
As far as splines matching, I would guess that no standard American spline will mesh exactly to a metric / European spline--you'll either have to have one custom made or buy metric splines and match other places (e.g., adjust shaft sizes to handle the metric spline).
Register to Reply 3 comments
Doogleass (1); rhkramer (1); Tornado (1)
