I recently came across an object with no discernible purpose or hint to its use. It is a brass tube-shaped device weighing about half a kilo, with a perforated sieve-like bottom that has been screwed on tightly. It looks as though this is to allow water to drain out, as there is a handle and hook at the other end. The handle is hinged on opposite sides, There is also a guillotine-style blade that slides through near the handle end.
Approximately 3.5 inches in diameter, and 9 inches long. 2.5mm brass thick, with the blade being made of 2.5mm thick steel. The blade has a small handle with "205" engraved, and 205 is also engraved of the mounting brackets. The entire device looks tarnished and quite old, but in excellent condition. All joins, rivets and fittings are very tight. Of notable mention are the 8 blind screws in brackets.
Many possible uses have been conjectured, from incense thuribles to potato slicer, but none seem entirely appropriate for all of the weird bits and pieces on this device.
"http://img547.imageshack.us/img547/4267/1090140.jpg"
"http://img510.imageshack.us/img510/2861/1090142.jpg"
