Previous in Forum: Electric Car Recharging   Next in Forum: Help 1988 Ford Ranger
13 comments
2005 Kia Sportage EX Stalling Problems
01/13/2011 11:57 AM
I have a 2005 Kia Sportage Ex 2.7l 6 Cyclinder. Toward the end of October 2010. The car would stall would coming to a stop or slowing down at a traffic light. Before it would stall the idle would jump around between 5 and 10 RPMs. Here are steps that have been taken up to this point:
1)My mechanic hooked it up to the computer and the code was a faulty Mass Air Flow sensor. So we replaced it. About two days later, It stalled again, so we cleaned the throttle body. Still the stalling problem continued. Please note the car always starts right back up again and the engine light has never been on. It road fine for about a week before the stalling began again.
2) In Deember 2010, took the car to Kia. They put it on the computer and it showed a code for a new O2 sensor. Before the changed it. they gave the car a computer software upgrade. Once the upgrade was done the code for the O2 sensor was gone.
The technician was hopeful that this upgrade would solve the porblem. That night about 6 hours later stalled again.
Took it back the next day to Kia and they did the Throttle body serrvice that was due on the car. The car did seem to ride smoother but it still stalled sometimes 4 or 5 times in a two block distance.
As of now January 13th, no codes show on the computer. The Kia guys were good to me because they could have replaced the O2 sensor and TPS sensor and charged me but they did not feel this is the problem. But as of now, myself and Kia are not sure what the problem is. The car has 55K on it. It's a been a great car. We are now at the probing stage with the car. My next step is to change the wires and the spark plugs because just before it goes through the stalling routine there seems to be a surge and from what I have read for the last month on the internet this can be related to the wires or the plugs. Anyone have any ideas? it would be greatly appreciated.
Thanks in Advance
Re: 2005 Kia Sportage EX Stalling Problems
01/14/2011 1:01 AM
A few things I'd like to know if you noticed them does it stall only after being driven for awhile or just after started (cold), any other conditions change while or before it starts to stall, any history of overheating or sudden temp gauge change and any repair and/or maintenance done right before stalling problem showed It's ugly head. There are a number of sensors, relays and control units (ECM) that can have intermittent signal problems/shorts. Get car in the driving condition when problem usually shows up and lightly tap with the soft end of a screwdriver the sensors,relays ect. see if one even starts to provide you with a stall also spray all gasketed connected areas with a little B-12 carb cleaner see if idle changes old school but is works- if a stall condition or rev up starts to happen You got that puppy by the tail! or well on your way. PS if idle jumps up I would think it's compensating for additional air OR fuel and or loss of vacuum Good luck Tim
01/14/2011 3:31 AM
01/14/2011 3:29 AM
take out the spark plugs and tell me what color the tips are.
01/14/2011 7:29 AM
Be sure to check all the vacuum lines and the idle air control valve (this can be cleaned after you take it out with a brake cleaner spray can (also clean the part where the idle air control attaches to))
When checkng the vacuum lines, make sure the engine is at normal operating temp. and move the lines around. The engine move around a little when you take off or come to a stop. Sometimes a small crack in one of the lines might not be visible untill moved. Listen toa small hissing sound when you move the lines around.
Good luck
11/05/2011 1:44 AM
I had that surge when i had a bad Master Brake Cylinder and an Alternator problem caused a rough ride. it was in a Nissan 200sx.ds
dsuzmay@gmail.com
Good Answers: 117
01/14/2011 8:03 AM
My bet is that it is sucking water/coolant.
Pressure builds up, thermostat opens, drops the pressure.
A real devil to find since the head gasket will only leak under high pressure. (if at all) When this happened on my old Tempest, we changed a sticking thermostat.
01/14/2011 8:12 AM
Don't know about the other codes, but going by the symptoms, a couple of other things to check are: 1) cam position sensor (can cause car to stall out if the sensor has an intermittent problem due to heat), 2) gas vapor solenoid (can't remember exactly what this is really named, but it's the solenoid that opens and lets gas vapor from the charcoal cannister attached to the gas tank flow up to the engine).
Good luck with this, let us know how it turns out.
Logan
01/14/2011 8:30 AM
My sister-in-law's KIA did the same thing. I just changed the spark plugs and she has not had the problem since, and that was at least 6 months ago.
01/14/2011 9:58 AM
the kia base engine is notorious for SHORT timing belt life recommeded replacement shortest in the industry 50,000 miles a check engine light will not trip for cam timing and engine acts like bad mass air ,throttle pos, idle air issues cam timing jumps back and forth due to rounded belt teeth we have had lots of dealer cant find the problem come in our shop only to be timing belt related. thank god for the customer this is a free wheeling engine!!!!!we have seen kia engines with as little as 39,000 miles have bad timing belts.
01/15/2011 9:39 AM
Don't know everything that has been checked, but, Unbelievable things can happen when the electrical system isn't supplying the correct voltage to components that operate on millivolts and poor connections can often be overlooked.
A good place to start would be to check all the connections right from the battery on down to where you can't see them anymore. That includes all the ground connections that you can trace and see. So far no one has done that and it is the first step a good tech will perform before condemning any other parts.
h
08/27/2011 10:45 PM
Just wanted to respond in case anyone encountered the same problem. Finally after 10 months of dealing with this problem of stalling the engine light finally came on after I already purchased the throttle position sensor a week ago and confirmed it was the throttle postion sensor. It's been in for three days and car has been perfect again.
Thank you to everyone who responded and gave their support.
11/04/2013 10:59 AM
Lakerpaul I was wondering if your car is still doing good since your last post about the problems you had with your Kia? I'm having the same problems. Thanks
01/20/2017 10:34 AM
I also have a 2005 sportage that has been thus far entertaining to diagnose. Mine only surges an stalls in Drive gear. P,N,R all idle an rev loaded an unloaded as should. No codes found or showing at all. Been fixing cars for over 30 yrs an I am officially stumped on this rig.
Register to Reply 13 comments
Against Late Models (1); Anonymous Poster (5); ds (1); Lakerpaul (1); lindafie (1); logan (1); Redneck (1); tmills (1); Yusef1 (1)
You might be interested in: Process Reactors, Reactors, Automotive Services
