Previous in Forum: Engine   Next in Forum: 2005 Kia Sportage EX Stalling Problems
22 comments
Electric Car Recharging
01/12/2011 4:53 PM
I have looked at some of the electric cars out there and all of them only "recharge" while braking?
Why is this, when the car is moving forward or backwards most of the time?
Would it not be better to design a car that charges its self while driving and not braking then most of the time the car would not have to be plugged into the house?
Just a thought and still not sold on the electric type car's out there, cost of car and replacement parts in the long run is too much of a cost compared to a "regular" car .
Re: Electric Car Recharging
01/12/2011 5:16 PM
You can't do that because... because.... aaaggghhhhh!!!!
01/12/2011 5:26 PM
That was tried once, but it didn't work very well. When coasting downhill with the brakes lightly applied the car overcharged itself and exploded, killing the inventor and destroying all his drawings and documentation.
The feat has never been duplicated.
I hear that LynDoor™Industries is working on a prototype that charges itself whenever the occupants pass gas.
01/12/2011 6:12 PM
LynDoor™ Energies is also working on another secret project. This one captures and saves the exhaust from the diesel genny on a locomotive. When the engine and train runs down an incline the exhaust is converted back into diesel. We accept the heat as lost, but we are still expecting a 50% reduction in diesel use when this system is functional.
We are having a little trouble with a few details, but expect to have it in our catalog within ten years. It will not operate correctly in the northern hemisphere. Ever.
01/12/2011 6:24 PM
Doorman,
I didn't even know about that one.
Wow, that LynDoor™ what a company. I hear they have a killer research center in Hawaii.
01/13/2011 1:17 AM
If your communication is no better than that, your folie à deux conglomerate will soon fall apart....
01/13/2011 9:30 AM
It's a new concept we're working on.
We call it "synergistic complimentary isolationism" whereby we each take basic concepts and develop them together while apart. Thus diesel fumes and farts both accomplish the same end through different paths.
01/12/2011 5:34 PM
Why bother with plugging anything into the mains when extension leads with more than one socket are available? - Simply plug the plug of the extension lead into one of the sockets on it and the appliance into one of the others.
01/12/2011 5:37 PM
Adding a generator connected to the electric motor(s) of an electric vehicle to charge up the batteries powering the electric motor(s) would require the electric motor(s) to have to work harder to overcome the generator load (as the generator provides more power the generator becomes harder to turn).
Put simply the batteries would always discharge faster if a generator was added in this way.
Regenerative braking is a special case because it doesn't matter that the generator would slow the vehicle because the car is slowing down already. You are converting wasted energy in the form of heat in the brake pads/discs to electrical energy that can be used to charge up the batteries.
Regenerative braking may not sound like much for highway driving where little braking is done, but just think about how much braking you do in the city (stop/start traffic, traffic lights, etc) on an average outing.
Good Answers: 114
01/12/2011 5:53 PM
The perpetual motion machine, build it and you shall have riches beyond measure.
01/12/2011 6:27 PM
Some hybrids do recharge while running, but they burn fuel to do so. There is no perpetual motion, over unity, or "free lunch" in this; but you can get some fuel economy sort of like a "reduced-price" lunch.
Good Answers: 60
01/12/2011 7:42 PM
Why is this , when the car is moving forward or backwards most of the time
current vehicles use friction to slow and stop the vehicle turning the vehicles motion and energy into heat thus the energy it took to get the vehicle moving is lost
Regenerative braking as used on fork lift trucks turns the drive motor into a generator so when you brake the power that got the vehicle moving is used to generate power which can be used to top up the batteries while slowing down
Would it not be better to design a car that charges its self while driving and not braking then most of the time the car would not have to be plugged into the house ?
How? Surely you can see this would defeat the whole purpose of having the electric vehicle
you could use a hybrid ie a small generator to charge the batteries while you drive but in order to completely over come the energy used in driving the vehicle say up hills the generator would be as big as a normal engine which would defeat the whole idea of having an electric car.
Good Answers: 59
01/13/2011 12:36 PM
peterg7lyq posted several times to have his account terminated, and so it was.
01/13/2011 12:40 PM
Good Bye Peter. You will be missed. Have a good life and be good to yourself.
01/16/2011 8:13 AM
My avitar has been removed, acess to my login has been suspended but my name is still on the site.
after much harasment by the moderators i asked for my profile to be removed, but it would apppear this is not going to happen why?
Good Answers: 918
01/12/2011 10:13 PM
I know someone that needs to pay more attention to thermodynamics this semester.
Good Answers: 119
01/12/2011 10:30 PM
To reinforce PWSlack's post:
If you can understand that the perpetual-power-strip
does not work, you should also understand that you cannot get free energy from a moving car. Regen breaking is just re-capturing a "small" portion of the kinetic energy you already used to get the car going and is the best you can do. Many people also don't understand that most of the energy needed to move a vehicle is used to overcome AIR drag and mechanical resistance and CANNOT be recovered.
01/13/2011 12:06 AM
Ha ha! Great pictorial demonstration of the idiocy of the concept of over-unity energy generation!
GA from me.
Good Answers: 918
01/13/2011 6:22 AM
There is one flaw with that design in your picture that will prevent that from working.
The AC switch is off.
Good Answers: 119
01/13/2011 11:06 AM
I had to power down for the photo. When active, the PPS distorts the local fabric of space-time. This severely distorts its appearance and any attempts to photograph it. I also did not include the special Distributed Ultra Magnetic Battery Assembly & Surge Suppressor which is critical for safely gathering unlimited free energy from nowhere.
Try not to step in stuff like this!
01/13/2011 9:22 AM
So, do you get different power levels, depending which tap you plug in to?
Good Answers: 119
01/13/2011 11:16 AM
Yes, each socket has a different capacity. However, every time I try to use full power (socket nearest the switch) the whole thing pops out of existence and I have to get a new one.
01/13/2011 12:44 AM
OK folks.
I maybe again bending too far over backwards but I think that the OP is missing a crucial point here, hence the question. Cut the guy/gal some slack.
A hybrid vehicle charges the battery during braking so that the kinetic energy of moving at a faster velocity does not get completely lost to heating a set of disc or drum brakes. To accomplish this the battery cannot be fully charged before braking or the energy has nowhere to go to be stored. Now sometimes a battery may fully charge before the vehicle comes to rest (going downhill) and sometimes the rate of braking needed exceeds the charging rate of the battery, so there must always also be an energy wasting traditional braking system. Additionally, sometimes a battery will get so deeply depleted in an acceleration that a slow charge maybe applied to bring a partial charge to the battery while the vehicle is cruising, but nowhere near a full charge for the above reason.
Reply to Forum Thread 22 comments
Anonymous Hero (2); Anonymous Poster (1); Doorman (1); jack of all trades (1); lyn (4); Mikerho (1); mjb1962853 (3); passingtongreen (1); peterg7lyq (1); PWSlack (1); redfred (2); SavvyExacta (1); Tornado (2); Usbport (1)
