Previous in Forum: 2005 Kia Sportage EX Stalling Problems   Next in Forum: Aluminum
Help 1988 Ford Ranger
01/14/2011 10:20 PM
1988 ford ranger 2.9 have spark and lots of fuel pressure but wont start
Re: help
01/15/2011 9:43 AM
How did you check the fuel pressure?
Good Answers: 58
Re: Help 1988 Ford Ranger
01/15/2011 3:29 PM
The shops usually charge $60 or so to check your computer and codes, but I would look for a used computer. Besides, these guys usually don't make house calls. At this truck's age, you should have spares of everything collected. I love my '90 but Ford doesn't love me, no help there. We are now delegated to the junk yards and back yard mechanics.
mike k
01/20/2011 11:26 PM
the fuel filter on the throttle body might all be plugged up...or it jumped timing...or if you are checking fuel pressure by taking off the fuel line and turning it over it still might not be getting fuel to the throttle body...or the switch on the clutch pedal might be bad if it isn't turning over.
Good Answers: 123
01/24/2011 6:53 PM
Do you have spark at the plugs? have you squirted a small amount of known good gas into it?
If so, it may be time to do a compression test. Compression and vacuum are directly related. Have an assistant turn the starter, and hold the throttle down. If you put your hand over the air inlet, the suction should be very noticeable. If not pay for compression test. If you feel hard suction, the valve timing is good.Look elsewhere.Good luck.
Bob
Register to Reply 4 comments
129CBRider (1); Anonymous Poster (1); bob c (1); mike k (1)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
