Previous in Forum: Hitachi Zx 330 Excavator Parts   Next in Forum: How 2 Hydraulic Cylinder Can Operate Simulteneously
Rubber Stiffness Vs Durometer
01/14/2011 3:27 PM
Is it possible for a rubber with a higher durometer to be less stiff than another rubber with a lower durometer? I thought that durometer was a direct indicator of a rubbers hardness and stiffness
Pathfinder Tags: durometer rubber stiffness
Re: Rubber Stiffness Vs Durometer
01/14/2011 4:20 PM
Durometer is a measure of the degree of penetration of a probe into the surface of a plastic sample.
Stiffness is measured by subjecting a specimen to physical deformation by manipulating the entire specimen.
You could test the same specimen both ways, but I don't think anything useful would result.
Unfortunately, you don't provide sufficient detail to continue.
01/14/2011 4:37 PM
The first answer is partially correct, the test is both a rubber and polymer test in fact the test really could be performed on any low tensile substance though is only a commercial application for the above.
Again as in the first answer it is a penetration test, I can see how you relate it to stiffness as it generally relates to a density test or test in respect to a substance being or becoming brittle, EG: some substances rate higher on the test are softer than a harder compound due to the density creating the increase in penetration pressure reading. the test itself is not an actual proof of either, simply a measure of an already known quantified test base.
In other words you cannot use the test on an unknown substance or new substance and get any sort of usable data in comparison to another product.
Why is it so? well a durometer has a speed over density flaw, a bowl of certain types of liquid at speed would resist a durometer where a solid piece of rubber/plastic/polymer would have less resistance. to show yourself how this is so, mix 4 cups of cornflour into a liquid paste and place in a bowl, now holding your fist vertical above it, punch the liquid with your fist, it will not enter the liquid at all, cornflour works like Kevlar as do many other substances, increases in speed causes the molecular structure to increase in density at pressure points at speed, all having varying speed levels. Thus a durometer would have a zero reading the same as if you dip your finger in the paste, yet have a complete barrier reading at high speed. Thus the reason it is only applicable to a certain range of products.
01/15/2011 9:20 AM
It is unclear to me how you could possibly expect the OP to understand anything you present here. It sounds like meaningless doublespeak. It would make Norm Crosby jealous.
01/15/2011 3:34 AM
Hadrness and stiffness are not the same thing (along with tensile strength, toughness, ductility, etc.) Some of these properties may correlate closely, loosely, or even inversely with others. Durometer is more of a hardness test than a stiffness test.
Good Answers: 58
01/15/2011 8:54 AM
Durometer is generally measured by an indentor and is specified in units of Shore (often Shore A). Stiffness is a measure of elastic modulus, modulus of elasticity, Young's modulus, etc. Its units are pressure or PSI. Because of the way most elastomers are used, durometer is often the critical parameter but modulus can also be specified if it is critical. There are other mechanical properties related to strain rate where the strain depends on the rate the load is applied. This is important to certain non-Newtonian materials such as silly putty.
Life is Enerventure (1); lyn (2); Tornado (1); welderman (1)
