Previous in Forum: How to Read Scanner Info Into 2 PCs at the Same Time?   Next in Forum: Search Light
Capacitors
01/15/2011 2:28 AM
Can we install a 20micro farad 440v capacitor instead of 20 microfarad 220v capacitor for :SON+MH150WATT PHILIPS MAKE search light? If we use what will happen?
Re: capacitors
01/15/2011 3:12 AM
You can.
United Kingdom - Member - British
Re: capacitors
01/15/2011 4:31 AM
It should be fine, the 440v one would be able to take up to, you guessed it, 440v and with only 220v in it there should be no problems... Only thing I will say is make sure the original capacitor is fully discharged before you go prodding around with it, unles you want a nasty shock.
bondy111
Re: capacitors
01/15/2011 6:49 AM
You replied nicely with the pre-caution one has to follow while replacing capacitors. As a member I would like to thank you.
Re: capacitors
01/15/2011 6:52 AM
You lost the opportunity to give answer as you are the real OP.
