Previous in Forum: Search Light   Next in Forum: What to Do With Opened Out Put of Live CTs?
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Anyone Knows About DSC & TGA
01/15/2011 3:10 AM
Hai all,
Any idea about the below items..
· DSC - Thermal analyzer for XLPE cables
· TGA - Thermal analyzer for XLPE cables
If you can't find a way, make one........
Re: Anyone knows about DSC & TGA
01/15/2011 7:32 AM
Differential Scanning Calorimetry
Thermogravimetric Analysis
Both tests are used in the analysis of a polymers composition.
01/15/2011 8:00 AM
Thank you for your help
Good Answers: 58
Re: Anyone Knows About DSC & TGA
01/16/2011 9:32 AM
Both these tests are used to characterize the physical properties of plastic insulation. DSC (Differential Scanning Calorimetry) is useful for measuring the glass transition temperature of materials. TGA (Thermogravimetric Analysis) measures weight loss with temperature and is useful for characterizing plastic performance. Neither test is normally used to directly identify a plastic formula, but more often as a quality control indicator of physical properties.
01/16/2011 11:50 AM
TGA use is not limited to plastics. It is commonly used in the ceramic industry to characterize raw materials.
01/16/2011 9:02 PM
XLPE = cross-linking polyethylene
It might not be abel to use DSC test due to its thermal stabilisation. However, its degree of cross-linking will be effected on DSC data. Comparison DSC and TGA for XLPE, TGA has seem to be more useful than DSC. The TGA data will get to know the minimum temperature of XLPE degradation that is low or high. Suggestion will be used to discuss or design to XLPE formular.
Good Answers: 58
01/16/2011 9:22 PM
A Google search under DSC XLPE shows many references such as http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=378879 I suggest DSC characterization not be dismissed for this application.
Register to Reply 6 comments
Anonymous Poster (1); justinanto1987 (1); Kraemir (1); lyn (1); welderman (2)
