Previous in Forum: Ball Mill   Next in Forum: Welding Flange To Plate
Single Cylinder
01/15/2011 1:55 PM
i need a motor to run automotive turbocharger compressor part ,,,,,i am working on single cylinder engine so i can not use entire turbocharger as it is because exhaust is coming in pulses,,,,, please tell me how i can do this
Re: single cylinder
01/15/2011 2:07 PM
1. Put a flywheel on the turbo shaft
2. Make it a supercharger and drive it through a gear box.
3. Find another way. There's not much exhaust coming from 1 cylinder.
4. Split the exhaust into 4 sub-tubes and alter the length of each to smooth out the flow, then meld them back together at the inlet of the turbo-charger.
5. Get a different hobby.
Good Answers: 18
Re: single cylinder
02/21/2011 11:49 AM
"meld" that got an off topic vote from me
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Register to Reply 2 comments
