Previous in Forum: 300kva 230v Generator Auto Starter   Next in Forum: Difference Between Relay and Release
18 comments
Electrical Engineering
01/16/2011 7:32 AM
Q1. Explain giving details of the various sections, the operation of a hydro-power station.
Q2. Explain briefly the factors to be taken into consideration while selecting a site for hydro-electric power station.
Q3. State the order of overall efficiency or thermal power station. Give reasons for its being of this order.
Q4. What is the fundamental difference between a thermal power station and nuclear power station?
Q5. State the considerations taken into; account for selecting a site for the construction of coal fired thermal, hydro and nuclear power station.
Q6. What are the different voltages, generally used in our country for generation, transmission distribution and utilization of electrical energy?
Q7. Discuss the advantages and disadvantages of transmitting large amounts of power over long distances using high voltage d.c. as compared to 3-phase a.c. Transmission.
Q8. What is the conductor materials employed for overhead transmission of electric power? Discuss their electrical and mechanical properties.
Q9. Describe with sketches a pin-type insulator used for high voltage lines showing clearly the fixing with cross-arm and binding of conductor. Why is insulator constructed with petticoats of different diameters?
Q10. Derive an expression for loop inductance in a single-phase transmission line.
Q11. Draw the layout of an a.c. secondary distribution system and explain it.
Q12. Mention advantages of ring main system over the radial system of distribution.
Q13. Explain giving reasons the basis for calculation of the cross-section of:
(i) Feeder (ii) Distributor.
Q14. Discuss most commonly used insulating materials employed for under ground cables.
Q15. Make a neat sketch of L.T. Line and prepare a list of the material required for one km long line.
Q16. Draw a neat sketch of an 11 KV line (one span only) and lable the various components.
Q17. What do you understand by substation? What are the important functions which can be performed at the substations?
Q18. State the advantages and disadvantages of outdoor substations over indoor substations.
Q19. Write a short note on a pole mounted substation.
Q20. Describe briefly the equipments (with their specifications) needed for an 11 KV pole mounted substation.
Re: electrical engineering
01/16/2011 7:41 AM
This will definitely test the patience of some great gurus.
Good Answers: 181
01/16/2011 7:45 AM
Ask your tutor to do your homework for you and see what his reaction is!
01/16/2011 8:39 AM
How many points is this worth and how do we get the points assigned to our grades.
Also, do you promise not to work on any projects where my life would be in danger by the poor workmanship and poor decisions you will be making as a future professional that did not do his/her homework and therefore is not qualified to do his/her job?
01/16/2011 11:00 AM
There are lazy people that ask us to do their homework and then there are stupid people that ask us to do their homework. This goes beyond lazy and stupid. This steps into the realm of insulting. I honestly hope that this lazy bum is going deep into debt to pay for this schooling. That the failing grade that they'll get from this class will shackle them for years to come.
01/16/2011 12:27 PM
I'll give the OP credit for typing without mistakes. I think it was typed, not cut and paste, because there is only one misspelled word, label.
I doubt the original publication would have missed this.
Still, it's over the top, for sure.
Good Answers: 804
01/16/2011 12:56 PM
I have to believe "lable" is one of most common misspellings in the English language. It's entirely possible that the text or worksheet the OP copied and pasted had it wrong to begin with, and the OP is too stupid to have used spell check, or even know what the little squiggly red lines under the word are in this forum posting box.
As I'm want to say when i see student postings like this:
You (the OP) must be a management student, not an engineering student, because your goal here seems to be to get someone else to do your work for you. An engineer would want to learn how to find this information in available resources.
01/16/2011 1:04 PM
Well put, put down.
It wasn't until I became a manager that I had to routinely asked people to do things that I was in capable of doing.
01/16/2011 4:20 PM
Only when labeling cabling.
Re: Electrical Engineering
01/16/2011 1:24 PM
<sigh>
If you did not pay attention in class then try an internet search, all the above answers to what look like homework questions can be obtained by an internet search.
CR4 is not a homework cheat site, and this appears to be university level homework.
01/16/2011 9:27 PM
Lets see if at all anyone got the guts to answer these questions. Thats because its not that simple to be ignored.
Reply Score 2 for Off Topic
01/16/2011 9:49 PM
Sure, here is a blanket statement from the moderators of the CR4 website that sums it up nicely.
http://cr4.globalspec.com/faq
What is CR4?
Conference Room 4® (CR4) is a forum for engineers, scientists, technical researchers, technical buyers, students and folks who just like technology to discuss engineering news, seek technical help and get answers to burning questions. CR4 is a community site supported by GlobalSpec, the Engineering Search Engine.
Are there specific rules for posting?
Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider this and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other college assignments is to help you learn - by practice, repetition, and self-discovery.
How much clearer can we be, CR4 is not a homework cheat site and we are not here to answer peoples questions.
Are you the 'Guest' poster of the original question?
01/16/2011 11:12 PM
You are not definitly helping the world to develop.Are you afraid of brain drain? Or Are you trying to be a good citizen to follow some rules which are meaningless at some instant?
Reply Off Topic (Score 4)
01/17/2011 1:59 AM
if you are that much smart why did you come here with your homework..???
You don't understand anything until you learn it more than one way.
01/17/2011 3:23 AM
Vijay i dont know who you are but you are not correct here.
Reply Off Topic (Score 7)
01/17/2011 7:07 AM
Q21: what's in it for any reader to respond to such a list?
The original poster is being lazy and is disinclined to carry out basic research to answer these questions.
Ans so should the potential respondent.
01/17/2011 9:13 AM
fine.......knowledge is not that easily gained.
i thought it was the problem with my collage and i am happy to see the whole world is the same which proves i get the best education.
all that horsepower doesn't come cheap.)
i just want to see how some great gurus respond, infact how does they approach to reach a solution.
sorry
01/17/2011 9:58 AM
I agree with you. GA
Banglore. Karnataka
Good Answers: 170
01/18/2011 12:37 PM
Straight out from your power system question paper?
Reply to Forum Thread 18 comments
Anonymous Poster (8); electricalexpert65 (1); jack of all trades (2); JRaef (1); lyn (2); PWSlack (1); redfred (1); TonyS (1); vijaymail_electrical (1)
