Previous in Forum: Controlling of Peltier Caliberator   Next in Forum: What Causes Under Voltage on Over Head Lines?
Calculate Lux from Lumens
01/18/2011 6:28 AM
How to calculate lux from lumens
Re: Calculate Lux from Lumen
01/18/2011 7:12 AM
I believe you will find that area has an important factor. Since lumen is already a unit that reflects the human eye's sensitivity, no weighting for spectral quality need be applied. This though is a very fundamental lighting question that can easily be considered as homework.
So I've given you a very big hint. Now go do the work yourself.
(All puns intended.)
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Calculate Lux from Lumen's
01/18/2011 7:55 AM
Total flux required = [(lm/m^2) x Area]/[Coeff. of utilisation x depreciation factor]
or
ø=EA/ηp
Good Answers: 73
Re: Calculate Lux from Lumens
01/18/2011 9:48 AM
•A Lumen is a measure of the light flux per some reference area.
• Total lumens refers to the total amount of power (in the form of light) that is emitted.
•Foot-Candle numbers refers to the apparent level of light at some distance from a source.
01/18/2011 2:53 PM
GA. I'd just add that 1 foot-candle is equal to 10.764 lux.
Or, more simply, define a lux as one lumen falling on a surface of 1 square meter.
Good Answers: 244
01/18/2011 6:57 PM
01/18/2011 9:35 PM
No no, not another link within CR4. That implies that the OP was just too lazy to use the "Search all of CR4" option on the right hand side of the page. Then again, the OP was too lazy to use Google, Lycos, Yahoo, any public library, or any university resource to look up this simple homework question. I guess that lumps us in with a few prestigious groups. That can't be too bad.
Reply Off Topic (Score 6)
hithuanand (1); msamad (1); NotUrOrdinaryJoe (1); redfred (2); Usbport (1)
You might be interested in: Lux Meters (Light Meters), Video Cameras, CCD Cameras
