Previous in Forum: Displacer Level Transmitter   Next in Forum: Burnout Settings in a Transmitter
Damper Pot
01/19/2011 6:51 AM
There is pressure transmitter for measuring "P" in reformer fire box in my application.
Range is min -50mmWC to +5mmWC.
One leg og PT is connected to PROCESS whereas one leg of it is connected to damper pot containing air with ambient conditions.
I am not clear abt the concept behind using damper pot in this case..
Could anyone explain plz.
Be happy :)
Re: Damper Pot
01/19/2011 10:48 AM
It's probably to slow down the response of the transmitter to process conditions, though what does the site Instrumentation Maintenance Supervisor have to say about it?
Good Answers: 29
Re: Damper Pot
01/19/2011 3:50 PM
A little more information on the instrument itself might be helpful.
Re: Damper Pot
01/19/2011 8:24 PM
For us non-metric guys, the cited range is approximately -2.0"w.c to 0.20" w.c.
Transmitters in this range are sometimes referred to as draft range transmitters.
The DP readings at this low range can be affected by moving air on the reference side, either as direct pressure on impulse tubing or as a venturi effect across the opening of a impulse tube.
I suspect that a damping pot is a chamber designed to damp air movement in the reference side impulse tubing that would otherwise be misinterpreted by the transmitter as pressure changes.
I've seen scintered filters on the end of impulse tubing or capillary tubing used for impulse tubing in order to damp reference side pressure fluctuations.
Re: Damper Pot
01/20/2011 9:27 AM
Thanks Carl...
Be happy :)
Register to Reply 4 comments
Carl_E (1); msn (1); PWSlack (1); RDGRNR (1)
You might be interested in: Damper Actuators, Rotary Dampers, Industrial Magnets
