Previous in Forum: Generator Overspeed   Next in Forum: Insulation Power Cable Requierements
10 comments
Charger Controller
01/20/2011 2:22 PM
hello, i wanna ask u all....i have battery charger 12V, that can be charge about 1.2A, now i wanna add the controller that can be stop automatically when the battery is fully charge, if can the controller use the PIC... any idea???
Re: charger controller
01/20/2011 2:34 PM
What's a PIC?
Is it made by MT?
01/20/2011 3:23 PM
It's a popular micro-controller chip made by Microchip. But you probably already knew that and were just tweaking us. Occasionally this has been confused with Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a Pict.
(One of my favorite Pink Floyd pieces.)
01/20/2011 4:20 PM
Just tweaking the Guest. Problem is, it probably was wasted on them.
Why can't they be like we are? Perfect in every way.
New Zealand - Member - Kiwi
Good Answers: 29
01/20/2011 2:47 PM
Yes, you can use a PIC microcontroller to control a battery charger.
I have used the PICAXE versions of these controllers for this before with success. Programming is simple and drama-free.
As well as just controlling the charge termination, you can use the on-chip PWM generator as the charge current control in this application.
paulusgnome
Good Answers: 119
Re: Charger Controller
01/20/2011 5:17 PM
There are many hundreds of free PIC app-notes with circuit and code already done for you.
Like...
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en010970
Please visit the manufacturers web site for more info.
If you want to make a charger without a micro, see my suggestion in this thread...
http://cr4.globalspec.com/thread/64224/Current-Limit-Circuit
01/21/2011 4:07 AM
Vellman Kit K8004. DC pulse width cotroller, it works, upto about 6Amps and 35V.
01/21/2011 4:03 PM
Why not just do it with a Unitrode (TI) charge controller? You can use a linear pass device
http://focus.ti.com/docs/prod/folders/print/uc2906.html
or PWM.
http://focus.ti.com/docs/prod/folders/print/uc2909-ep.html
Good Answers: 119
01/21/2011 6:51 PM
Good point! There are many smart charge control IC's which are much easier to use than a microprocessor or a discrete circuit.
01/21/2011 10:25 PM
but, i didnt find the best circuit that can intergrate with my battery charger, can u give me the ideal circuit that can be automatically stop when the battery is fully charged, i just found the 1 of the way is by using relay, that in certain level of voltage, it will flip from on to off.....
01/22/2011 12:02 AM
Lord man what do you want us to do? You've been given application links to the very micro controller you originally asked about. You've been given links to other controllers designed specifically to charge a battery that will not require any programming. Do you want us to solder the chips to a prototype board for you and hand you back a few reams of test data, a cost comparison and an anticipated battery longevity analysis for each approach? $%&^$#
Anonymous Poster (2); Brave Sir Robin (1); lyn (2); mjb1962853 (2); Paulusgnome (1); redfred (2)
