Previous in Forum: NVR and CCTV Cameras   Next in Forum: Radio Direction Finder
26 comments
Cleaning Your Soldering Tips
01/20/2011 11:03 PM
My soldering iron has been caught up with too much plastics that eventually when cooled down. It completely can not be removed from the soldering iron tip. Are there any othere form of lubricants that i can use to remove that other than the solders. Thankyou!
Re: Cleaning Your soldering Tips
01/20/2011 11:20 PM
Plug in iron, when hot; wipe off plastic with wet cloth, re-tin tip.
Don't do it again. Your soldering iron is not a plastic welder or cutter.
There is no lubricant, if you want the iron to tin again.
Take up wood burning, clean tips aren't required.
Reply Good Answer (Score 4)
Good Answers: 266
01/21/2011 3:09 PM
It's not a plastic welder or cutter? Then I was lead astray. Was instructed to use one to burn the carpet through to the air holes on a air float table for flat glass. Worked pretty well for that melted the hole and seared the lose fibers up real well. Have to call that tech up and give him *****
01/24/2011 5:47 PM
....soldering iron is not a plastic welder.... Generally I would agree; however, we have been using Weller irons with modified tips for heat staking Delrin, Kel-F & Torlon (at different temperatures of course) for 16 years @ an estimated 50.000 to 75,000 joints per year! With initial modification and dressing about once/day with 400 grit sand paper, we get about 3500 joints out of each tip.
Of course once they are modified (exposing the copper) we never mix these tips with the solder tips. Unless you plate them ($$$) they would never work well.
What is right is not always popular. - What is popular is not always right.
01/21/2011 4:00 AM
Worst case you can file it cold and the n heat and re-tin.
(I too use my soldering iron for welding plastic occasionally...I'm a baaaad kitty, maybe Mrs Cat should give me a good spanking?)
Good Answers: 29
01/21/2011 7:47 AM
Weller discourages filing or sanding their tips. I believe because they are plated. The cheaper irons can be filed to your hearts content.
I had problems with a technician constantly stealing borrowing my expensive Weller iron and using it to install inserts into molded plastic housings. The process invariably coated the tip in plastic. My solution was to get a cheap Radio Shack iron. I used some 8 awg copper wire to make tips for it. Cut a short length, tap threads on one end and file the other to a point. I still had to lock up the Weller tho'.
I've had some success using a variac to lower the temperature on the cheap irons as well. Makes it easier to work with plastics without burning.
(What you and Mrs. Cat do in the privacy of your home is none of our business.)
01/22/2011 7:41 AM
Some makes of soldering irons can use solid copper wire just by sliding it in and tightening the set screws. I believe mine accepts 6 gauge.
Good Answers: 29
01/21/2011 11:10 AM
Once you get your tip clean keep a bowl at your workstation with a small damp sponge in it. Wipe off the tip occasionally to keep it clean. Damp cats work too but they don't like it!
01/21/2011 11:42 AM
Damp cats work too but they don't like it! And their fur really stinks when burnt.
My first real job was changing sponges and replacing flux cups in a large production shop at Motorola. This was prior to surface mount, everything was thru-hole and hand soldered.
Good Answers: 114
01/21/2011 10:33 PM
A wire wheel is a little easier on the tip than filing
01/21/2011 11:02 PM
Copper wire( desolder wick), make a small ball of desoldering wick,hold this ball with a rag and rub it on the tip when it is hot. If it requires more cleaning add a little solder paste to the ball. Keep this ball,you may need it again.
01/21/2011 11:08 PM
There are small containers of flux and a grit combination available in which you can rub your tip till it is clean again ,also there are bronze and stainless steel scrubbing pads especially for soldering iron cleaning. Certainly do not use a file or similar to clean tips it will damage the steel coating. Solder pots can be of help to dip the tip into it, you first apply a liberal amount of flux to the tip and then dip and repeat until desired result. Use in combination with a small steel wire brush it will help.
01/22/2011 1:36 AM
if you have bought a half decent iron.. they put in the box or on the packing lots of writing... some of that writing is the instructions on how to use AND CARE for your iron.
have fun with your iron.. one word of warning, as you seem to want to use it for most things, DO NOT use it in open heart surgery for quarterizing wounds..
Good Answers: 130
01/22/2011 5:14 AM
Ever laid your iron on the bench then leaned your forearm on the barrel?
That cauterizes quite nicely.
01/22/2011 5:34 AM
more times than I care to remember.. and it SOOOOOooooooo hurts too!
You'd think you'd learn from the first time! Na!!
01/23/2011 5:21 PM
They work well for searing finger tips also! - and not only the iron, the item you have just finished soldering ....
01/22/2011 3:27 PM
I use mine to remove warts.They don't come back if you go deep enough.(Trial and error method.)
Doesn't hurt the tip a bit,except for some charring, which will burn off eventually.
01/23/2011 12:43 PM
Ew!
01/23/2011 4:51 PM
Isn't that painful?
Good Answers: 12
01/23/2011 7:16 PM
ARE YOU ME? I have a nice round scar on my right forearm from doing just what you describe. I only did it once though.
Bill
01/23/2011 7:41 PM
Yes, watch out...its a bit easy to do but believe me, considered it risky. Thankx
01/22/2011 6:43 AM
Get another tip. Keep one for plastics and use the other only for soldering. Or 2 extra tips and keep one only for silver soldering.
01/22/2011 7:29 AM
Good day Guest. I also use the iron for "other" functions that they didn't design it for. The best cleaning method for me is a small piece of corrugated cardboard with one side wetted with some dish-soap. To clean the solder tips I simply stick holes into the card board. regards
Re: Cleaning Your Soldering Tips
01/23/2011 7:02 AM
I do second the advice in #1 that never use for any other job including plastic-welding as soldering tips are more costly and very difficult to clean after such use.
I further add the use of Soldering Sponge for normal cleaning during work.
Wet-Sponge is used for the purpose of trouble free soldering. Other posters had already added it.
Filing of tips is now not / cannot be done now. The new technology of Tips is more advanced from copper tips.
01/23/2011 8:31 AM
I think the posters have lost track of the original question, it was how to remove plastic contamination from the tip not how to maintain the tip in normal use which is to use a damp sponge to wipe off oxidized solder not burnt plastic contamination.A damp sponge is relativity infective to remove burnt plastics it is to gentle and it does not re tin the tip as it cools down the tip to a point where contaminations freeze on the tip and stay there. It requires a mild abrasive which cleans fluxes and re tins the tip in one operation, or other methods as I previously mentioned.
Good Answers: 12
01/23/2011 7:35 PM
Very good ideas above. When I reach a point where the sponge won't take the gunk off, I will scrape the tip with an Xacto blade. This is not the best fix, but I have the knife here on the bench, while I do not have sandpaper or a wire wheel available without doing alot of running around. My current PTR7 (Weller soldering tip) has about had it though after a couple of years, so it is time to get a new one.
Bill
01/24/2011 7:07 PM
I have cleaned some soldering iron tips with dry ice. Take the hot soldering iron tip & push it straight into a piece of dry ice & as the dry ice boils off with a high pitch sound it takes the crud off of the tip leaving it clean as new. I think the high pitch noise acts as a ultrasonic cleaner.
Reply to Forum Thread 26 comments
34point5 (1); Anonymous Poster (3); Doug (1); electrone (1); garth (2); Garthh (1); Haajee (1); Leonf (1); Lo_Volt (1); lyn (2); mann935 (1); max11 (1); ozzb (1); phph001 (1); RDGRNR (1); Sciesis2 (2); thccontrols (2); U NO WHO (1); user-deleted-1105 (1); WAWAUS (1)
