Previous in Forum: Chutes and Airbags for Flying Cars and Hovercrafts   Next in Forum: Propane to Gas?
Piping Material for Piping Material
01/21/2011 4:22 AM
In one of our polysilicon project, we have decided to use the following pipe materials for HCL service.Kindly comment for the same Gentlemen :)
1) service : Anhydrous HCL ( vapour), design press .=2Mpag, -46/200 C
Material anticipated A 333 Gr 6.
2)service : Anhydrous HCL ( liquid), design press .=2Mpag, -85/100 C
Material anticipated 316/316L.
3) service : HCL ( 0 to 35 % Aqueous), design press .=1.5Mpag, 75/200 C
Material anticipated PTFE lined.
suggest alternative if any.
Re: piping Material for piping material
01/21/2011 5:19 AM
If this is hydrochloric acid, the correct abbreviation is HCl (the L/l being lower case.)
Most of these materials can be found in various corrosion-resistance and pressure-capability sources that will be helpful.
The nickel richness of 333-6 is good for low temperatures, but I'm not sure how it applies to acids.
(Just a few sketchy ideas.)
Re: Piping Material for Piping Material
01/21/2011 9:41 AM
"Plastic, plastic, plastic" - like, PVC, like PP, like PVDF, like PTFE.
Check-out the Cole-Parmer materials compatibility database.
01/21/2011 1:36 PM
I'm with PWSlack.
Ryan Herco, Herrington Industrial Plastics and others can also supply piping materials.
I worked for a company that built chemical etchers (among other things) and we used plastic pipe extensively. It's lots cheaper than titanium or Hastelloy C-276 and other exotic metals.
Most importantly, ask the supplier if he will certify the pipe for your use.
Milo may have some information, too.
01/23/2011 11:54 PM
Thanks for valuable comments.
01/26/2011 6:31 AM
have a look also at this publication from NIDI
http://www.stainless-steel-world.net/pdf/10020.pdf
hope this help
S
corrosion prevention
01/26/2011 10:46 PM
wonderful information strider6, Thanks :)
01/22/2013 8:15 AM
the performance of ceramic tube will be the best choice for pipe liner,abrasive-resistant and corrosive-resistant.
www.fuboon.com,ceramic pump,precision ceramic balls,ceramic knives,ceramic tube,ceramic discs,all fine ceramic products.
Register to Reply 7 comments
Anonymous Poster (1); HSN-PIPING (1); lyn (1); michaelzhuo (1); PWSlack (1); strider6 (1); Tornado (1)
