Previous in Forum: 30 Mechanical Engineering Subjects Video Lectures   Next in Forum: Solenoid Valve in Hazardous Area
Queries on Weld Strength
01/22/2011 1:59 AM
I would like to find out the tensile stress experienced by the weld when for the situation mentioned below. I have a pad eye that is welded to a structure made up of hollow tubes, so that the structure could be lifted. When the structure is lifted, can i assume that the forces acting on the pad eyes will be the same forces acting on the weld (Weld material welded between the hoolow structure and the pad eye), in order for me to do my analysis on the weld strength? I have attached a picture.
Re: Queries on Weld Strength
01/22/2011 3:29 AM
Where is the attached picture?
01/22/2011 3:46 AM
Good Answers: 114
01/22/2011 10:34 PM
what material?
what type materials?
what size?
Good Answers: 179
01/23/2011 12:15 AM
Briefly, you're going to need to figure the weight of the lifted structure + lifting impact forces as well as momentum forces due to twisting about a cable in order to properly design the welds and the lifting pads.
Materials? Yield stresses? welding electrode grade and types? static weights/loadings? number of pick points? What type of hollow tube, as in round or square or rectangular?
Frankly, you need to obtain a really good "lifting design" textbook as well as review the code requirements. Many municipalities today require that a qualified Professional Engineer design the lifting system, prepare the drawings and affix & sign his /her PE seal on the drawings, and finally prepare the actual LIFT PLAN. All of this is required because that have been too many lifting failures in the past, with quite a few fatalities.
Check online or request the Lifting Code requirements and regulation of both NYC and Chicago, some of the best in the world as well as the most stringent. Their respective building departments can assist you with your questions.
Good luck with your endeavors!
Signed,
CaptMoosie, PE/PhD
Civil, Structural & Environmental Engineer
Good Answers: 179
01/23/2011 12:17 AM
Oh, I forget to mention some important factors regarding the static and dynamic loadings......don't forget the wind loads and ice/snow loads where applicable!
CaptMoosie (2); Garthh (1); Tornado (1); vanuta (1)
