Previous in Forum: Shipping Overseas   Next in Forum: How Green is Green Industry Highlighting "Green Automotive"
8 comments
SA 516 Gr 70 Plates
01/24/2011 1:55 AM
Dear Guys,
Hope you are all well..
I want to import SA 516 Gr 70 Plates.. Can some one advise me which size and thickness are more preferable when manufacturing pressure vessels and heat exchangers?
Best regards
Abdul Ghaffar
Re: SA 516 Gr 70
01/24/2011 2:18 AM
For pressure vessels, the plate thickness is essentially proportional to pressure times diameter. This gives a wide range of possible plate thicknesses. For modest sizes and pressures, plate thicknesses of 0.25" (~6mm) to 1.00" (25.4mm) would be common. However, if the destination requirements tend to be for larger and higher pressure vessels, the balance would shift toward thicker plates. For this you need to asses the market conditions at the destination.
Re: SA 516 Gr 70
01/24/2011 2:44 AM
Dear Sir,
Thank you for your kind answer.... do you have any idea about the common sizes being used??
Re: SA 516 Gr 70
01/24/2011 2:59 AM
I once worked in a small to medium scale pressure vessel shop where thicknesses went up only to 0.750" (~19mm). Your requirements (or marketing opportunities) might differ, which I don't know how to predict.
Re: SA 516 Gr 70
01/24/2011 2:19 AM
that depends on the size and thickness of you PV and HEX per design calculation. and the availability from mill.
Re: SA 516 Gr 70
01/24/2011 2:44 AM
Thank you sir
Re: SA 516 Gr 70 Plates
01/24/2011 11:50 PM
most popular thickness values are 8 - 12 mm
01/25/2011 2:58 AM
Actually, we use plates of ASME SA 516 Grade 70 with thicknesses range from 6.35 mm up to 32 mm with plate width up to 3 000 mm (depending on the max. width of our rolling machine) and plate length up to 13 000 mm (depending on the max. required outside dia. of vessel). And there are another plates with higher thicknesses, widths and lengths, depending on size of vessel and its design conditions (pressure & temp.), by applying ASME (or any) code rules.
................................o
01/25/2011 11:20 AM
The company i work for produces A516-70 over 3" ,76mm, T. This is in use for pressure vessels. One of the major problems with the thicker plates is the centerline segregration which can open up when the plate is formed due to the shear stresses at the centerline.
I suggest any A516-70 that you order undergo ultrasonic testing to detect this problem.
Ron
Register to Reply 8 comments
Abdel Halim Galala (1); Abdul Ghaffar (2); Anonymous Poster (2); mr.varan (1); Tornado (2)
